Old 07-26-2013, 02:08 PM   #1
ksshane
ksshane's Avatar
drop kits for 71 with leafs?
can anyone point me towards some drop kits for my 71 C10. It has leafs in the back instead of springs.
Im looking for some drop spindles and then a flip kit. Just not sure which if Ill need lowered springs for the front and if so what size. Thats why I was hoping to find a kit. If someone already knows what all I need to order I dont mind ordering it seperatly.
Would like to get as low and as level as possible without putting in a C notch or bottoming out.
Any help is appreciated. And if you have the same set up and have added a drop I sure would like to see it.
ksshane is offline   Reply With Quote
Old 07-26-2013, 02:21 PM   #2
rogergodding
rogergodding's Avatar
Re: drop kits for 71 with leafs?
ECE has drop leafs that will get you 4 inches and shackles that can give you a total of 5 1/2....
http://earlyclassic.com/catalog.aspx
rogergodding is offline   Reply With Quote
Old 07-26-2013, 02:47 PM   #3
rogergodding
They also have drop spindles and coils for the front. I've had their drop spindles on my truck for 12 yrs or longer.... You can buy all as a kit too...
Old 07-26-2013, 03:27 PM   #4
sKnNyPpY
sKnNyPpY's Avatar
Here's a write up I did on my DJM flip kit, about 6" drop I guess. DJM is about the only company doing flip kits for the 2.25" leaf springs. I also used 2.5" drop spindles and 1" springs up front.
http://67-72chevytrucks.com/vboard/s...d.php?t=577529
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 07-26-2013, 03:39 PM   #5
ksshane
ksshane's Avatar
Awesome. Thanks guys
