Should I Strengthen my Frame?
I'm Working on my 72 K20 and i hear so much about people strengthening the frame on these trucks that i wasnt sure if it was a normal thing to do. My main plan for this truck is to be used both off-road and on-road. My main uses off road would be mainly hauling wood and probably some mudding. On road i would use it for some towing and driving. I dont plan on racing but i may do some kind of engine/transmission swap in the future. Any advice is welcome! Thanks!
My K20 build http://67-72chevytrucks.com/vboard/s...d.php?t=538539 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Should I Strengthen my Frame?
Stronger is always better, but is not always needed..... and for normal use like you have described, I's say it's not needed. I've owned my '72 K20 for 36 years and have put it through quite a lot, though I wouldn't say I've abused it, just worked it pretty hard at times. Nothing has broken.
I wouldn't worry about it unless you crack the frame,Places like a steering box brace or maybe a better engine crossmember i would.Steering box brace http://offroaddesign.com/catalog/steeringkit.htm and http://diy4x.com/cart/index.php?rout...&product_id=80
Thanks for the info guys, as long as I am taking everything apart I thought it might be a good idea to do it just in case It needs it in the future. If I was going to strengthen it what is the best thing to do?
Grease Monkey
Frame flex is actually a good thing. It prevents damage to your frame.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Only place that needs it is the steering box mount those are known for cracking or opening up the holes in the frame.Unless you use the truck hardcore off road like jumping the frame is fine now.
If your not beating on it i would put the money elsewhere
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
If it's a 72 it may already have a reinforcing bracket / plate for the steering box on it from the factory, Mine does ! Look on the inside of the frame behind the steering box for a brace that fits inside the frame rail, between the frame & the front crossmember.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
