![]() Join Date: Apr 2009
Bouncing gas gauge qustion
Thread should say "question"
My 83 has dual tanks, after fuel level gets down below 3/4 the gauge seem to be constantly moving around and bouncing. Is there a fix for this? or is it a common problem. My 87 with the electric fuel pump takes a different sender I know, but does not have any issues with the gauge. Desert |
Re: Bouncing gas gauge qustion
Mine has a similar problem, and I think the problem is the sending unit on mine.
Moderator
![]() Join Date: Oct 2008
Solid tank and gauge grounds and solid sender wire connections...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
I think the fuel just sloshes around more when low
As I recall some gas gauges had a resistor to move slower to prevent bouncing Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
GM really screwed the pooch on this one. Not only did they mess up on the gauge side of things, they messed up on the sending unit side as well. The way I fixed it, was to buy a gauge from autometer. It won't accept the wildly fluctuating 0-90 ohm signal from the sending unit, so easily. It waits before it adjusts the needle. This cuts out most of the wavy needle problem, though you will still see it move from time to time.
To truly fix the problem, you also have to get a tank with better baffles in it, such as the newer ones with that big piece of foam in there. http://www.chevyclassicsclub.com/the...ry-1965-newer/ |
#6 | |
My wife's 77 3/4 ton with dual tanks does the same thing. That needle bounces all over the place ALL the time. Gonna have to try that Autometer gauge.
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
I was thinking bad ground or connection.I've been wrong before too.
78K & 79C Jimmys
When i got my 78 Jimmy it did this
I read up on it decided to live with it when i changed to the stock cluster with tach, it went away when i wired the cluster up i had to add a ground for the gauge
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Yeah I used to hate that dang wavy needle. Its like not even having a gas gauge lol. There are some people that claim you can get lucky buying a high quality, ACdelco brand sending unit (that whole apparatus) and it will fix the wavy needle. Some have done it and got lucky, others bought the same thing and had no results.
I like the idea about the ground. I always thought there had to be a way to let the signal through, but just do it once per minute. Instead of 6 times a second. That way, the needle would seldom ever be seen moving, but the gauge would still work just fine. |
78K & 79C Jimmys
just to add
it was idiots to tach/gauges in the 78 i read people had issues with spectra senders I can see a spectra stamp on the 78 tank assumed it was a spectra sender but in the 79 I went with a spectra tank and sender and it didn't bounce before or after Posted via Mobile Device
