Old 07-27-2013, 09:52 AM   #1
McCoyAZ
McCoyAZ's Avatar
One more rear axel bearing question?
I didn't have a bearing puller so I used a long steel rod to push the old bearings and seals out from the inside of my '64.
Since I was on the opposite side of the truck I did not get to see the order in which these 3 parts came out of the housing.
I think the large flat metal washer goes in 1st, then the bearings and then the seal?
Is that correct or no?
McCoyAZ is offline   Reply With Quote
Old 07-27-2013, 07:15 PM   #2
McCoyAZ
McCoyAZ's Avatar
Re: One more rear axel bearing question?
Nobody??
Old 07-27-2013, 07:24 PM   #3
19666Trucker
19666Trucker's Avatar
Maybe when I get home pull out my manual,
19666Trucker is offline   Reply With Quote
Old 07-27-2013, 07:38 PM   #4
T Smith
T Smith's Avatar
It's been a while but sure don't remember that flat washer.
Went and looked in my shop manual, don't see that washer. The bearing goes in first, then the seal, then slide the axle in.
T Smith is offline   Reply With Quote
Old 07-27-2013, 08:32 PM   #5
McCoyAZ
McCoyAZ's Avatar
It definitely came out of there, one on each side....
It is a flat sheet metal disc I am assuming it is a bearing stop, but I don't know and I can't find a reference to it anywhere except on chevy mechanics blog I read.
Old 07-27-2013, 11:14 PM   #6
Jeff La
You don't want the washer between the bearing and the seal, so to me the washer has to go in first.
Jeff La is offline   Reply With Quote
Old 07-27-2013, 11:18 PM   #7
cru_zn_29
cru_zn_29's Avatar
Maybe washer was used to space bearing outward on axle. I have used axle savers before but they don't look like what u have.
Kenny
cru_zn_29 is offline   Reply With Quote
Old 07-28-2013, 09:02 AM   #8
19666Trucker
if you got back look at your picture of the brakes it shows the seal, bearing, then washer
