Closed Thread
Old 07-27-2013, 05:53 PM   #1
twouvakind
twouvakind's Avatar
Holes, everyboy's got them....or do they?
I am seeking places to mount the "remote control" of the wiper delay unit I offer. Are the holes pictured in the images "factory"? One is by the e-brake and one is to the left of the ign. switch of my 72. Do other model years have these holes if they were/are factory? What were they intended for if the are/were factory?
twouvakind is offline
Old 07-27-2013, 07:20 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Holes, everyboy's got them....or do they?
I believe they are factory holes. My truck has the hole above the parking brake release, complete with original paint. It's clearly not a drilled hole.
The other hole has the aftermarket fuel gauge selector toggle switch, so I'm less sure about that one.
It was there when I bought the truck in 1977.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline
Old 07-27-2013, 08:14 PM   #3
twouvakind
twouvakind's Avatar
Great feedback, please keep the comments coming!
Old 07-27-2013, 10:48 PM   #4
FirstOwner69
FirstOwner69's Avatar
My 69 has only the hole above the brake release handle. Nothing near the ignition switch. I can assure you that's the way it came from GM.
May vary by year and production date though.
FirstOwner69 is offline
Old 07-28-2013, 08:08 AM   #5
twouvakind
twouvakind's Avatar
Very interesting, so far we are three for three on the hole by the e-brake. Anybody else care to chime in? Thanks!
Old 07-28-2013, 12:39 PM   #6
swamp rat
swamp rat's Avatar
I have the hole by the key, I have my dash apart to do some work, and add the wiper delay, i thought about trying to mount it there also, will have to check into that later.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline
Old 07-28-2013, 03:03 PM   #7
camrycurt
camrycurt's Avatar
My 70 has both holes. I've found they're the perfect size for 1/2 inch aftermarket toggle switches. I've used both - one for a light control switch and one for the switch for my amp.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline
Old 07-28-2013, 06:27 PM   #8
twouvakind
twouvakind's Avatar
Thanks for the feedback...both, like my 72 has.
Old 07-29-2013, 12:11 AM   #9
swamp rat
swamp rat's Avatar
I was thinking, possibly tooling holes for ether manufacture or alignment? also possibly different from plant to plant as well?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-30-2013, 02:04 AM   #10
Captainfab
60-66 Nut
On my '68 the hole on the left above the e-brake is there, but on the right by the ignition switch, the hole is there but it is only about 1/4"-5/16" diameter. I forgot to check the '67 that is in my shop, but I would imagine it is the same. The '69 parts cab that I have has both holes as your '72 does Bill.
Captainfab is offline
Old 07-30-2013, 09:10 AM   #11
twouvakind
twouvakind's Avatar
Thanks for the input everybody. Judging by the first batch of potentiometers I ordered, the hole(s) would not work. I am going with a bracket to mount the pot or drill 5/16" hole in the bezel to mount it directly. I will give the buyers of the delay the option to do either.
Closed Thread
