07-27-2013, 10:41 PM | #1 |
Shock Mount Repair
Hey all, just wanted to share my fix of my front shock mount on my '86 shorty as you can see in the first pic it had a gigantic hole where the shock had been loose and egged out the mount badly...I took a piece of 1/4" plate and shaped it to fit with a grinder then tacked it once to get the placement right then filled the gaps what do you guys think?
07-28-2013, 12:28 AM | #2 |
Re: Shock Mount Repair
Looks good. The frame is a heavy duty spring steel so a grade 8 washer works good too. It's a good fix for everyone though shock braces from a 4x4 off lmc truck do well at preventing issues as well
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
07-28-2013, 12:32 AM | #3 |
One of my shocks was loose for a long time, fortunately the frame was ok.
07-28-2013, 12:36 AM | #4 |
Ya I was originally going to go the easy route and just use a grade 8 washer, but there was to large of a gap at the top and the bottom still and it didn't sit right in the hole either, I was worried about it tearing out again so I went with this
07-28-2013, 09:22 AM | #5 | |
While I would definitely agree with adding the 4x4 bracket to put the bolt into a "double shear" situation.....the frame is not spring steel.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
07-28-2013, 02:26 PM | #6 | |
