![]() Join Date: Jul 2009
Sway Bars for the 4x4 Jimmy/Blazer...??
Hi Everyone,
I have been looking online for quite a while now and can't seem to find any large aftermarket sway bars designed for the 4x4 versions..? If I do find one, then it's only 7/8" thick.. I am looking for a beefier bar maybe 1 1/4" or so in that area for both the front and rear... since I will be towing things later on with it.. Any suggestions or site with pics would be greatly appreciated.. Have a great day.. !! PS I have a Dana 44 front and 12 bolt rear w/a 4 inch lift if that helps.. ![]()
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. ![]() |
![]() Join Date: Apr 2010
Re: Sway Bars for the 4x4 Jimmy/Blazer...??
See Krazyray I believe the blazer didn't come with a sway bar. I bought a bar from him with the cross-over piece . The cross over piece has the u-staps mounting plates. Some guys have made the plates them selves to bring the bar down to the height(4inch lift) Do a search good luck
!972 K5 Blazer,Highlander,A/C a twin to the one I Had 1972 K/5 Blazer ![]() 2003 Silverado Crew 2500HD (Daily driver) 1997 Ford focus (Beater) 2003 ford Taurus (student) 2014 Ford Fusion HYB (wife) 2003 Jetta ( Student) |
#4 | |
Thanks Silverado,
I will PM him and see what we can do.. Quote:
I have both sway bars. The front one comes with the later factory crossmember that replaces your 72 and all of the mounting hardware. You will need some grade 8 bolts and rubber bushings and I believe you will need to add 1" shims to your crossmember to go with the 4" lift. The front is $115 total including shipping to socal. The rear bar comes from a 1 ton dually with mounting hardware. You will need longer u bolts, washers, nuts, and bubber bushings. The rear is $150 total including shipping to socal. PM me with your email so I can send pics.
Thanks, Ray Thanks 3003 silverado! |
The deal is sealed.. Again, my hopes have been fulfilled.. Got both sways bars from Krazy Ray.. So if you need them, contact him and he can find what you need..
