6 lug to 5 lug swap
I have my 72 5lug axles I want to swap over to my 68 rear end. What is my step by step process? I remember that the diff needs to be opened up to remove something, but I just can't afford any surprises when doing this swap.
1968 Chevy C10 swb fleetside ![]() 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) ![]() |
Re: 6 lug to 5 lug swap
they wont work 5 lugs are longer
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
67-72 parts collector,…
![]() Join Date: Nov 2002
You will need to buy aftermarket 5-lug axles for the narrower 67-69 rearend.
Check Moser Engineering.
Quit if it's not FUN!!!
You should sell me those '72 axles. They will fit my '70. Send me a PM if you're interested. I'm up in Fort Mill, S.C. and come to Columbia frequently.
Well... That sucks. How about me swapping the entire rear end drum to drum?
#6 | |
The 71-72 rearend is 1.5" wider (total) than your '68 rearend.
So if I was to swap the rear end, it would look like a clown car with the tires sticking out too far?
#8 | |
It's only 3/4" per side wider.
take your axles out and drive them to rossville GA to hudlow axle and they can redrill them for 180.00 dollars
#10 | |
Otherwise you will have to use 71-72 brake drums. This will require the center hub of your 6-lug axles to have to be machined to a smaller diameter.
![]() Join Date: Apr 2012
Your best bet is to go with the moser 5 lug conversion. I wouldn't mess with redrilling anything. Although it would work.
Posted via Mobile Device |
#13 | |
#14 |
Let me thoroughly weight my options first before I make a decision. Because I really want to put some 5 lug cragars ss on this truck.
1968 Chevy C10 swb fleetside ![]() 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) ![]() Last edited by primetime; 07-29-2013 at 12:08 PM. Reason: Spe |
#15 | |
67 right 68-72 right 67 left 67 left w/115"wb w/side mount spare cutout 67 left w/side mount spare cutout, except 115"wb 68-72 left 68-72 left w/115"wb w/side mount spare cutout 68-72 left w/side mount spare cutout, except 115"wb Any apparent placement of the wheel relative to the fender lip will depend on four things. installed axle width WMS to WMS wheel width wheel backspacing axle laterial centering
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 07-29-2013 at 05:41 PM. |
