Old 07-28-2013, 04:01 PM   #1
Irishbleueyes
Installed GMC Grille today have a question
Turned on the low lights and the hi's have a glow then switch over to the hi's and the low's have a glow, is that normal??
Irishbleueyes is offline   Reply With Quote
Old 07-28-2013, 04:26 PM   #2
Irishbleueyes
Re: Installed GMC Grille today have a question
Heres the pics
Old 07-28-2013, 04:35 PM   #3
McCoyAZ
McCoyAZ's Avatar
Mine do not do that.
Maybe a grounding issue?
McCoyAZ is offline   Reply With Quote
Old 07-28-2013, 05:15 PM   #4
63burban
Chevy addict
Yup, ground issue
63burban is offline   Reply With Quote
Old 07-28-2013, 09:02 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Are you sure you have them wired up correctly? It sounds like the wiring is connected backwards. It may be wired incorrectly at the grille harness, from where it connects to the bulkhead connector next to the radiator, or the wires may be mixed up and running to the wrong bulb connectors.
The way these four lamps systems work - High beam bulbs only have one filament and a two prong connector on the back. The low beam bulbs have two filaments and a 3 prong connector in the back. The two filaments in a low beam lamp are 1. High Power - this is the normal low beam lamp output. 2. Marking light/dim power. When high beams are selected at the dimmer switch, the normal low beam filaments in the low beam lamps go out, and the dim filament lights up to serve as a marker to show you have 4 headlamps.
You may find the wiring diagram in the following thread helpful in debugging the system. Just ignore the relays and follow the wiring from the battery and dimmer switch to the lamps. You'll notice the high beam lamps are wired to the low power filament in the low beam lamps. Something in this circuit is the source of your problem:
http://67-72chevytrucks.com/vboard/s...d.php?t=387693
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 07-28-2013, 09:08 PM   #6
ky-donzi
Ground is unhooked, or bad connection...so to complete the circuit it's drawing a ground through the other lamp.... It can burn up your wiring do to the extra amps drawn though the circuit
61 GMC 4x4 1-ton flatbed 4bt cummins, ranger od, sm465, np 205, d60F, d70R 4.11 10,000 ramsey PTO winch.... SOLD
73 k5 gm crate 350-265 / sm465 / np205 3.73 posi
ky-donzi is offline   Reply With Quote
Old 07-28-2013, 09:16 PM   #7
ky-donzi
