Control arm question
Does anyone know if there is a aftermarket lower control arm that will fit a 1970 C10 with 15 X 8 wheels with 3 inch Belltech drop spindles
Re: Control arm question
Probably not much help, but I have a set of lowers from Performance Online that I used with 2 or 2.5 drop spindles as well as lowering springs (don't remember how much). Don't know about the 15x8s though since I'm running 7s.
I used their uppers too, and I'm pretty happy with the way they worked out.
“If you don’t have time to do it right now, how will you ever find time to fix it.” - author unknown '70 SWB Step-Side (More rust than metal) ![]() |
Thanks ill research them a little more I don't think they will work though. If I had known that 3in drop spindles with 15 x 8 wheels with a 4 in backspace would be such a pain in the @ss. I would have went with 2 1/2 drop spindles or bigger wheels.
#4 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Less backspace or a larger diameter wheel will definitely make your life easier,... but you never know when you might have to bolt on a set of 15" wheels up front.
I am running 15x8(4" backspace?) rally wheels and 3" bell tech spindles with trimmed stock control arms.
Wheels do not rub the control arms at all. I do have a small issue with wheel weights rubbing the tie rod end though. |
