Old 07-28-2013, 06:58 PM   #1
mikekaye69
drive shaft for a shortbed 350 turbo
Hey all..... Well..getting very close on putting my 2004r in my truck.. I did a complet check<cleaned & painted it.. Putting the lockup switch this week into the trans and have everything for the trans..."except" im gonna need a drive shaft for a 350trans.. I know the yoke is the same as the 2004r as for the 350turbo.... Now, the 400 trans i have is longer then the 350/2004r.
Any ideas on the length of the standard 350 driveshaft is???? I read its 59.5" long....Is this correct. And im sure all short beds from'73-87 will work. Any suggestions...would be much appreciate it.. Cause there's a truchshow in Carlisle,Pa. on August 1-4th..gonna try there..but will call the junk yards before then. Thanks!!
mikekaye69 is online now Report Post
mikekaye69 is offline   Reply With Quote
Old 07-29-2013, 09:06 AM   #2
Re: drive shaft for a shortbed 350 turbo
This is a pickup...2wd/4wd? You had a TH400 and now a 200r4? If it's in the truck,just put your old driveshaft in and measure how much more you need. You'll probably have better luck on the pickup message board
Old 07-29-2013, 05:32 PM   #3
mikekaye69
Re: drive shaft for a '87 2wd. shortbed 350 turbo
I have messured the shaft that its there rite now with the th400. from rear-universal joint to the front universal joint is just over 54".
Old 07-29-2013, 08:53 PM   #4
Unca
measure and cut a driveshaft down, have it balanced by a shop... gtg and a TON cheaper
Unca is offline   Reply With Quote
Old 07-29-2013, 09:43 PM   #5
meatwagon83
meatwagon83's Avatar
measure the one you have, if you dont have one get a tape measure and a buddy!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
