07-28-2013, 08:59 PM | #1 |
3/4 ton gear ratio
Does any know if 3.73:1 gear ratio was available in 1967 3/4 ton rear ends? Or if they are available in after market products? Any help would be appreciated.
07-28-2013, 10:32 PM | #2 |
I have a radical idea!
Re: 3/4 ton gear ratio
I'm pretty sure 4.10 is the highest gear in Eaton rearends.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
07-28-2013, 11:34 PM | #3 |
The Eaton HO52(5200) is going to be 4.57 or the optional 4.10. In 68 they offered a Dana 60 in 3.54 (big block trucks) that continued with the later trucks. If you are running an Eaton 4.10 is really as good as it gets. Bigger tires, an O/D or O/D transmission and a factory Dana 60 swap would all be good alternates. If you don't mind fab work a 14 bolt could also be used.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
07-28-2013, 11:39 PM | #4 |
As mentioned,no 3.73s were available. To get 3.73s you either need a 14-bolt or a Ford Dana60. BBC automatics came with 3.54s in a Dana60
07-29-2013, 02:58 AM | #5 |
Learning As I Go
do dana 60's come in these trucks with coils?
1972 Chevy C-20 Longbed 2wd Granny Low with a Crate 350: Air Gap Manifold, Edelbrock 600cfm, HEI, Headers to a 40 series flow (soon to be dual again) |
07-29-2013, 04:10 AM | #6 |
Dana 60 axles were offered as optional equipment with leaf or coil springs on some 68-72 CK10-CK25 trucks, mostly with HD springs or big block manual applications. If you want the BOM numbers, download Dana Spicer's X510-8 that can be downloaded here.
www2.dana.com/pdf/X510-8DSD.pdf
