oil coming out of breather.
I just got my old truck back and now when i bring it off Idle and get into the mid rpm range it forces oil out of the breather hole on the drivers valve cover.
The holley I have on the carb does not have a large PVC port on it so its not hooked up now. Is this causing the oil to come out? too much crank case preassure maybe. if so I can T is off were the power break fitting is right? thanks.
"Buckle up I wanna try somethin!!" "of course it will hold!, I welded it!" 1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint |
Re: oil coming out of breather.
Tee it off to the manifold. You don't want to conprimise the brakes in any way
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Robert Olson Transport
![]() Join Date: Oct 2002
definitely your problem
ok thank you. can I use any port on the manifold that has a pipe plug in it? have one on both sides of the distributor but they are on intake runners so wasnt sure if they are for coolant sensors. IF not i will use the vacuum port that my trans vacuum is hooked to.
