Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-29-2013, 01:55 AM   #1
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Blaster Abrasive Breakdown and Vacuum failure
Here’s a tip from the website of a company called Skat Blast, a media supplier...and a good tip it is!
“Regardless of which abrasive you use, change abrasive on a regular basis,
as visibility problems inside a closed cabinet will increase as the abrasive breaks down in
consistency. Once the abrasive breaks down to a consistency of a fine powder, the fine
particles will pass through most vacuum bags or cartridges, resulting in failure of the vacuum or
dust collector motor, and often blowing dust into your shop. It is not economical to
blast with worn out abrasive and doing so is one of the chief causes of vacuum motor failure.
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 07-29-2013, 10:36 AM   #2
cdowns
cdowns's Avatar
Re: Blaster Abrasive Breakdown and Vacuum failure
i've stoped using a hipriced vaccume system on my cabinet// i go to yard sales and buy $10 shop vacs use em till they fail then i just plug in the next one// i will usually have at least two in storage for backup
i blast alot of aluminium valve covers and manifolds so that worn down media actually gives a rereal good resale surface
