Heater box caulk
As you can see my cab as been completely redone and now it's time to put the heater box back, I need to know what I should use as a sealer between the heater box and the firewall, both inside the cab and outside.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
Re: Heater box caulk
GM used 3M Strip Calk (thats how they spell it) at the factory but that was on the engine side of the firewall.
![]() There was no sealant between the heater box and the cab side of the firewall - the sound dampening material provided the seal. But if your insulation blanket is long gone, the 3M Calk works good. Only problem is - the smallest box they sell contains 60 feet of the stuff (60 X one foot strips) - about 15 dollars. |
I will get some of the 3m Strip Calk.
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
I just did mine and used plumbers putty. Never dries out and you make it ad thick as you need it. Tighten up and remove the excess.
Posted via Mobile Device |
#6 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
I ended up getting some from Eastwood, nice stuff.
Should work well
I stopped by NAPA on my way to ACE this afternoon and got a roll of windshield seal. Worked perfect.....
I am getting ready to reinstall my heater box would Dap roof caulk be a suitable substitute? It seems to stay plyable and would be resistant to oil. just a thought I know a roofer so it is easy to get.
5 out of 4 people have trouble with fractions |
I would stay away from plumbers putty and tube caulking. When you need to replace your heater core you will have a gooy mess.
what he said. I had to remove my heater box right after installing it with the windshield seal and it was terrible. Just buy a gasket set- it'll come with the foam seal for the box.
I was wondering about the foam seal
#13 |
The calk you may find on the shelf or hanging on the rack at your local hardware store. May not be under the 3M name. Looks like a thin package of kids plasticene. You even have (had?) a choice of colors. We often used what was boxed as "Crack Seal".
We used to use that stuff when cabling to seal holes. The exposed side will skin over, but it will remain pliant, I've removed some that I jammed in a hole some 20 years ago and could still work it. Alex. Last edited by Axle; 09-22-2013 at 10:32 PM. |
#14 |
#15 |
You have seam sealer which is like caulk but for cars,Or you have 3m window putty no clue on how that one handles heat tho.
#16 |
I just used strips of self-adhesive urethane foam window and door stripping from Home Depot. It looked like what I had in there originally when I removed the heater box. I like the 3M strip caulk idea also, but I have never seen it in person.
#17 |
Moderator
![]() Join Date: Oct 2008
Yup!! The strip caulk is already pre-formed but the old fashioned windshield seal will do the job nicely.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#18 |
Until you have to take it off. It sticks so good you risk breaking the heater box...
#19 |
The heater gets very warm, but it is not fire starting hot. I can't imagine that it would get hot enough to melt or set on fire regular foam weatherstripping.
| Bookmarks |
