Old 07-29-2013, 07:38 PM   #1
CYLFD
CYLFD's Avatar
Suggestions for air management mounting
I'm looking for ideas on what some of y'all have done about mounting your air management controls etc.
I have Porterbuilt stage II rear with Accuair elevel and I'm trying to find the best place to mount all manifold etc. I also have dual tanks with Porterbuilts bracket for the tanks and compressors on the side of the frame.
Any help,ideas, pics of what you've done or seen would be greatly appreciated these are really nice parts so I want to make sure and do it right the first time.
CYLFD is offline   Reply With Quote
Old 07-29-2013, 08:04 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Suggestions for air management mounting
I am wondering the same thing as I dont just want to throw them in the bed.. Im thinking along the frame rail between the cab and rear tire..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-30-2013, 07:10 PM   #3
Square_78
Square_78's Avatar
My Accuair eLevel is mounted to the outside of the frame behind the cab and in front of the rear wheel on the drivers side. I'm using the exo mount system and it fits perfect. Dual compressors and 5 gal tank.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 07-31-2013, 04:19 PM   #4
CYLFD
CYLFD's Avatar
I was thinking of some where like that does any of it hang down or visible?
Thanks for the input.
Old 07-31-2013, 10:14 PM   #5
502ms
502ms's Avatar
Step or fleet?
Raised floor or hump?
All of my air equipment is hidden. Tank on a custom bracket on my raised floor, compressors on brackets along the side and up inside the bed walls. Nothing visible.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 07-31-2013, 11:25 PM   #6
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Here's what I did with my manifold. There's a bed in it now and everything is still pretty accessible. It's just mounted on one of the AVS compressor mounts, but I'm not sure if there'll be room for your ECU.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline   Reply With Quote
Old 08-01-2013, 06:13 AM   #7
502ms
502ms's Avatar
Looks good Steve
Best Regards,
Leon M.
Old 08-01-2013, 08:16 AM   #8
Square_78
Square_78's Avatar
@CLYFD. I have the exo mounted so that the bottom of the mount is level with the bottom of the bedside. You can only see it if you look under the bed. You can mount it higher if you wanted.
#teamlongbed
Old 08-01-2013, 04:31 PM   #9
CYLFD
CYLFD's Avatar
Originally Posted by 502ms View Post
Step or fleet?
Fleet no raised floor
Old 08-01-2013, 04:34 PM   #10
CYLFD
CYLFD's Avatar
Thanks for the input I'm still playing with different locations. I don't want it to show but want it some what accessible.
Old 08-01-2013, 04:35 PM   #11
CYLFD
CYLFD's Avatar
Hey 502ms what clutch set up you running in your T56 if you don't mind me asking.
Old 08-01-2013, 07:41 PM   #12
FRENCHBLUE72
PROJECT 7DEUCE
Looks like I'll order the exo mount and put it on the frame thanks guys..
MEMBER #6377
Project "7DEUCE"
