What hubcap for my rims?
Gentlemen, and Dan.
![]() Sorry couldn't resist giving you some $hit, you never miss a post! What hubcaps fit my rims? I am not sure what year these rims are from but there are no rivet on clips. Thanks!! ![]() Are there several different types for this style rim? I am wondering if they look like these? ![]() Last edited by sqrlnts; 07-29-2013 at 09:36 PM. |
Re: What hubcap for my rims?
Ok, so a little homework findings. i think the 55+ hubcaps here
And the ones on the middle right should fit. Yes? |
#3 | |
![]() ![]() Join Date: Nov 2008
Big UGLY ones! ![]() Since you're giving me $hit, I'll give it right back to you.
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
Ok, YOU can!
But seriously, it's a little hard to tell from your picture but I THINK your rims have the "bumps" on them to hold the hubcaps, right? Even if you could put the spring hubcap retainers on them and the caps would fit, the bumps showing would look odd, wouldn't they? And I THINK the ones that fit on those bumps ARE kinda big (and ugly to me, no offense). The '64-'66 ones HERE: http://www.truckandcarshop.com/trucks60_72/t60_150.html But the very fact that the '57-'59 caps are pictured in the '60-'66 catalog makes me wonder if they'd fit OVER the bumps? I've always liked those. I LOVE steelies with beauty rings and small caps to the point that I plan to get a 2nd set of rims like that at some point as an occasional change of pace look!
![]() Join Date: Aug 2010
The wheel has a safety bead lock so it most likely is '67 & up. There may even be a date code stamped in the rim.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
Those are later wheels. The original wheels use an "inside clip" which can be bought separately and installed with rivets but as Dan recognized, you'll still have "ugly" because those nubs will be hanging out.
I have similar wheels on my truck. I've spent more $$ on cheap (and not so cheap) baby moon caps over the years than I want to add up but they only last a couple of years before they rust. A neighborhood dog sprayed the last ones while the truck was parked outside and they rusted before a week had passed. I'd decided I'd had enough and dedicated a few days to looking for stainless covers. I finally found a set made by Phoenix. They're marketed for trailers but they fit my truck wheels perfectly. You can see pictures of the trailer baby moons here: http://www.nueratrailerparts.com/c-2...ps-covers.aspx Once I found the correct hubcaps I ordered them directly from Phoenix: http://www.phoenixusa.com/ What was really tricky was that the published ID for the cap didn't match the size of other caps that I'd bought. IIRC I bought the 1307SS for my 16" wheels. I can probably dig out the receipt if necessary. My stainless trim rings are from 88-96 Chevrolet trucks. I was working in a dealership when I was restoring the '57 and I'd tried a ring from a used truck on the lot so I knew it would fit my wheels. A customer's new truck had arrived and as I was prepping it for delivery he said "Don't bother putting the trim rings on. I'm buying aluminum wheels." So I got a smoking deal on four brand new GM trim rings. Last edited by 1project2many; 07-30-2013 at 07:33 AM. |
what is the diameter of the place the cap goes? If it is a 16 wheel for later disc brake (68+) application these will fit. The upper photos are for 68-72 K5/10 applications with 10.25" back diameter (10.5 front). K20/30 applications look similar but are 1" larger diameter. The originally came in paint, stainless and chrome.
The lower are for 72-78 K5/K10 and are cheaper and lighter material. I got a set of the upper ones for mine. The came with and without beauty rings, I have a set of those too.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
basically stretches over those little nubs towards the center
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#10 | |
I WONDER (since the later rims w/the "nubs" are common) if you could grind off those nubs - yes, it would leave an oblong hole - and weld in a patch from a damaged rim/grind smooth? Then install the "inside clips". I don't think this would be a structural concern as the hole wouldn't be on the rim portion and if you welded in the patch before grinding off the next nub, there'd be little chance of heat deforming the rim. (I honestly think the rims are too thick to have to worry about that too much anyway) Thoughts?
That's a fair amount of work. Clean and weld the inside / back side of the nub first, then cut and grind the unwanted portion off.
sounds like alot of work!
granted mine is a different year i still have the same wheels 4 and 3 nubs but still 6 lug mine look smooth and simple with full moons
#13 |
If they are fifteens I think a lot of the so called "poverty caps/cop car caps" will fit and you may not have to stay with truck caps unless you want to. Sometime along in the 70's or 80's they had small caps with a bow tie in the middle that would look great on an older truck.
Maybe a nice set that were similar to this http://www.ebay.com/itm/Vintage-Chev...00b78d&vxp=mtr Or 56 car caps http://www.ebay.com/itm/56-Chevy-210...ab4a49&vxp=mtr Those are just examples to get the brain cells charged up and not a suggestion to buy those particular ones. I'd find an old one locally and try it before spending any money on a set though.
#14 | |
#15 |
Elev8r Man
I am running 53 car full caps on mine, they need a lot of massaging but still look pretty good. I am running 86 C10 rims so they are very similar to yours with the nubs.
Just a thought. Posted via Mobile Device
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
#16 | |
![]() Join Date: Jun 2011
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
