Old 07-29-2013, 11:51 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Brake question on 72 4x4
Redoing the brakes on a 72 Cheyenne short box. Master cylinder is completely gone could not get any pressure at the bleed valves when trying to bleed the lines. The fluid that I did get through before all pressure was lost was full of rust grit and settlement. I went ahead and ordered new booster, master cylinder, and wheel cylinders from NAPA. Only problem is the master cylinder doesn't look anything like the one that's on the truck or I remember seeing on any 72 Chevy that I've come across before. What do you guys think?
Well I can't get my photos to upload from my phone. I will have to upload them when I get home to my computer.
The part number is P2062
Here is a link to the picture on NAPA website
http://m.napaonline.com/parts/PartsList.aspx?k=P2062
The one on the truck has equal size reservoirs front and back this one has a smaller compartment for the back fluid. It is quite a bit thinner as well.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 07-30-2013, 12:09 AM   #2
Mister-B
Re: Brake question on 72 4x4
Why replace the booster if it is fine? You could just get a master cylinder, and bolt it up (make sure you get a MC that's designed for a booster and disc brakes, since you have a 72).
Not sure why the napa one looks different. Have you entered your vehicle specs at autozone or Oreillys to see what theirs looks like?
Mister-B is offline   Reply With Quote
Old 07-30-2013, 11:03 AM   #3
lts70
1970 Daily Driver
lts70's Avatar
http://m.napaonline.com/parts/PartsList.aspx?k=P1880
This one looks closer but still isn't exact. The one that is on the truck has two retaining bars to hold the cap on. This one only has the one.
Old 07-30-2013, 04:21 PM   #4
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
Raybestos MC36280 is what you need, it has the dual-bail cap. The one with a single-bail wire is for 1970 and older trucks with drum/drum brakes.
http://www.carpartsdiscount.com/auto...186623&slide=6
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
