Old 07-30-2013, 09:30 AM   #1
mlevario99
Exclamation Wiper Washer Jar Location on a 66
Does any one have a picture of where the bracket that holds the washer jar is located in the 66 trucks.
mlevario99 is offline   Reply With Quote
Old 07-30-2013, 10:16 AM   #2
1963c-10
1963c-10's Avatar
Re: Wiper Washer Jar Location on a 66
Will mount on the driver side of the radiator support, just over the horn relay. You will see 2 holes where the washer bottle mount goes. I can get a pic here at lunch time.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-30-2013, 10:19 AM   #3
mlevario99
Thanks 1963c-10, if you could post the picture, also, if you can get the picture of how the hose runs from the jar to the pump, I know there is a 3 hole gromet in the cabin.
Thanks again
Old 07-30-2013, 10:20 AM   #4
1963c-10
1963c-10's Avatar
Heres one I have on file. I will see what I have for factory hose routing
Old 07-30-2013, 12:17 PM   #5
Lugnutz65
Lugnutz65's Avatar
These photos are of a 1966 bracket that I just took 2 weeks ago. I just sold one of these brackets on eBay and took these pics before I sold it. The upper hole is centered 2 and 3/16" to the outside (left) of the vertical edge on the radiator core support and is centered on the top rail. Pics explain it better than words.
The lower hole can be located by using the bracket. I would do a quick test fit before drilling since other accessories are tucked pretty close right beneath it.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-30-2013, 01:06 PM   #6
Lugnutz65
Lugnutz65's Avatar
OK, so I made a boo boo on the measurement. I should have said 2 and 3/32". Sorry about that.
