2WD Jimmy
![]() Join Date: Mar 2005
Removing a small tap
Yesterday I broke off a 10-24 tap that was 5/8" into the cast iron portion of one of my spindles. The tap snapped off 2 threads down into the hole. Crap...
I remember reading on the Practical Machinist Forum where a guy said he used his tig torch to build up the tap with .040 stainless rod. He used a .040 tungsten and a 1/2" gas lense to build up the tap to about 1/4" above the hole. Then he placed a small washer and nut over the built up tap and welded the nut to the tap. Then he backed it out with a wrench. I thought ,"that'll never work", "that tap is in there tight and its tool steel". I was wrong, it worked, see my pic. I know this will probably get moved and thats fine, but I thought it was a neat trick for you guys to catalog in your mind for future use. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Removing a small tap
Great Job Tom!! Great piece of info! WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Active Member
![]() Join Date: Jul 2007
Pic? Attachment not working for some reason.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Not bad....
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
2WD Jimmy
Thanks for posting my pic Tim. I emailed it to myself hoping for an automatic resize... didnt work, ended up in a zip file.
Cluster King
![]() Join Date: Nov 2012
I have had several taps break off in holes and I have always had to use a center punch with a nice dead blow or ball peen hammer and just break them apart until they fall out of the hole they broke in. Face shield is highly recommended for this. I don't have the luxury of a tig so that would not work in my case. Great idea if the tig is available. The nice thing about tool steel is that it is on the brittle side and will break into smaller pieces if need be.
nice job an old friend of mine has a welding shop i saw him do it many times works perfect
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
