Old 07-30-2013, 08:52 PM   #1
eagleuh1
eagleuh1's Avatar
Balljoint torques?
Anybody know the torque specs for 85 3/4 ton C20 ball joints, upper and lower on the ball nuts , and upper for the 4 mounting bolts to upper control arm. Trying to get my disc conversion done, can't find the specs. Mounting on my 68 C20. Thanks. Jim
eagleuh1 is offline   Reply With Quote
Old 07-30-2013, 09:20 PM   #2
SS Tim
SS Tim's Avatar
Re: Balljoint torques?
If you want, here is a link for the square body service manuals that cover most years except 85. He does however have both 84 and 86 along with many others.
http://67-72chevytrucks.com/vboard/s...d.php?t=545416
The 67-72 manuals are here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 07-30-2013, 09:50 PM   #3
Rufton
MOOG UBJ:
1/4" 10-14 ft.-lbs.
5/16" 14-19 ft.-lbs.
1/2" 55-65 ft.-lbs.
5/8" 75-90 ft.-lbs.
9/16" 60-80 ft.lbs.
MOOG LBJ:
7/16" and 12 MM 40-55 Ft. Lbs.
1/2" 55-65 Ft. Lbs.
9/16" and 14 MM 65-75 Ft. Lbs.(except Aluminum knuckle).
5/8" and 16 MM 75-90 Ft. Lbs.
11/16" 90-100 Ft. Lbs.
3/4" 100-120 Ft Lbs.
18 MM 100-120 Ft. Lbs.
Vehicles with aluminum knuckle 50 Ft. Lbs.
Rufton is offline   Reply With Quote
