Old 07-30-2013, 11:08 PM   #1
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Gulfcoast Build Updates (pics)
Hey Guys I have been at a stand still for a while but I'm thankful to be back at it again.. Well today I got my engine and trans dropped in..
Still have alot to hook-up, but I also received today my Bowtie Overdrive Package for my Carburater bracket and Spring for the tv valve so when I drop the pan for that I'll also wire the tcc lock-up...
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 07-30-2013, 11:12 PM   #2
gulfcoast66
64-66 CHEVY JUNKIE
Re: Gulfcoast Build Updates (pics)
Old 07-30-2013, 11:16 PM   #3
gulfcoast66
64-66 CHEVY JUNKIE
Old 07-30-2013, 11:19 PM   #4
gulfcoast66
64-66 CHEVY JUNKIE
4l60
Old 07-30-2013, 11:23 PM   #5
gulfcoast66
64-66 CHEVY JUNKIE
Old 07-30-2013, 11:30 PM   #6
gulfcoast66
64-66 CHEVY JUNKIE
Transmission Crossmember..
Old 07-30-2013, 11:34 PM   #7
gulfcoast66
64-66 CHEVY JUNKIE
It fit nice high and tight...just need to drill the holes in frame..
Old 07-30-2013, 11:36 PM   #8
gulfcoast66
64-66 CHEVY JUNKIE
Old 07-30-2013, 11:42 PM   #9
gulfcoast66
64-66 CHEVY JUNKIE
Carburater Bracket
Old 07-30-2013, 11:44 PM   #10
gulfcoast66
64-66 CHEVY JUNKIE
Old 07-31-2013, 12:59 AM   #11
Captainfab
60-66 Nut
Looks good. I'm sure it must feel good to be making some progress
Old 07-31-2013, 12:26 PM   #12
gulfcoast66
64-66 CHEVY JUNKIE
Thanks Capt. And yes I'm glad to get the ball rolling again.....
Old 08-01-2013, 09:40 AM   #13
gulfcoast66
64-66 CHEVY JUNKIE
Here's one with the 1980's style 15-8 Rallies.
Old 08-12-2013, 11:48 PM   #14
gulfcoast66
64-66 CHEVY JUNKIE
Today I got my serpentine belt bracket 90% done, I still have to bend the power steering bracket back in shape I bent it up a Lil when removing it .
Old 08-12-2013, 11:51 PM   #15
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-12-2013, 11:56 PM   #16
gulfcoast66
64-66 CHEVY JUNKIE
Have anyone installed one of these on your steering shaft at the rag-joint??
Old 08-12-2013, 11:58 PM   #17
gulfcoast66
64-66 CHEVY JUNKIE
Old 08-13-2013, 12:02 AM   #18
gulfcoast66
64-66 CHEVY JUNKIE
Posted via Mobile Device. Here is where I need to connect it..
Old 08-13-2013, 01:04 AM   #19
Captainfab
60-66 Nut
I have never installed one of those, since I make my own......what do you need to know?
Old 08-13-2013, 01:47 AM   #20
gulfcoast66
64-66 CHEVY JUNKIE
Capt. I need to connect the shaft back to the Rag-joint.. But I really don't trust this piece I got with my power steering kit.. I know that I need a whole New Rag-joint the Old one is dry rotted.. Capt what do you have that can get this connected??? Thanks for you time
Chris..
Old 08-13-2013, 12:13 PM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used DD shaft and rag joints to mate my tilt column to the rag, and added a support joint.
iirc the rag end is from the 72 we got the steering pump from
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-13-2013, 08:36 PM   #22
gulfcoast66
64-66 CHEVY JUNKIE
Br3w do you have anymore pics of how you connected the two together???
Old 08-13-2013, 08:39 PM   #23
gulfcoast66
64-66 CHEVY JUNKIE
*support joint*
Old 08-14-2013, 01:29 AM   #24
Captainfab
60-66 Nut
This is what I offer to connect the original steering column shaft to the rag joint.
Chris..
Old 08-14-2013, 11:02 AM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
3/4 DD shaft is a standard size, which 99% of the aftermarket stuff fits. Keep in mind, I hooked up to a tilt column, which started with its own DD shaft stub.
You can page through my build if Photobucket decides not to be a terrorist today.
Because of the angle and combo of parts, I go
Tilt column (3/4 DD) -> DD Universal Joint-> DD shaft-> DD U joint + support -> 72 rag joint stub into steering gear.
The support joint is a special oversized heim joint from AllStar. I have a short video on the bracket fab and installation being edited now and should be out soon.
