Old 07-31-2013, 02:45 AM   #1
In The Ten Ring
Brake drum puller and jack stands?
I have a strong feeling I'm going to need one of these.....does anyone know if Advance Auto loans brake drum pullers out?
What is a good brake drum puller to buy for this sort of job?
Where do I put the jack stands to remove the rear drums on a 1972 Chevy swb 2-wheel drive?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 07-31-2013, 07:25 AM   #2
Daddy Brim
Daddy Brim's Avatar
Re: Brake drum puller and jack stands?
No puller needed, use the adjusting wheel to back off brake shoes. You can get to it from the bottom back side of the drum. Some times a BFH helps. I put my jack stands under the axle housing, be sure to block both sides of front wheels.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 07-31-2013, 07:54 AM   #3
volksworld
shoot the area where the axle sticks thru the drum with penetrant a couple days in advance...that's where they rust on
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 07-31-2013, 08:47 AM   #4
truckdude239
truckdude239's Avatar
Ive never seen a drum brake pulleri normally just beat them off since i replace the drums when they are stuck on
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 07-31-2013, 10:10 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
^What they said^.Also be aware that if you use drum puller,you will probably have to replace all the brake hardware,At 40+ years old,it might not be a bad idea anyway.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-31-2013, 12:18 PM   #6
In The Ten Ring
Thanks guys but...
What's "BFH?"
What's an "axle housing?" Where is it? I'm serious.....I am VERY new to all of this! If it isn't putting in gas, changing oil, or changing a tire, I am a novice.
Will go put penetrating oil onto the brake drum right now though....it'll be next week before I can start on those anyway.
Old 07-31-2013, 12:26 PM   #7
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Big F------ Hammer. 3 to 5 lbs short sledge hammers work best....
The axle assembly is what the rear tires bolt to.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 07-31-2013, 12:28 PM   #8
71meangreenc10
You have to be careful not to smack the studs unless you want to replace them. My advice is to get a good repair manual to help you out. Everyone has to start out from somewhere, they are great referrence materials.
Smitty
Born and raised in Charleston West By God Virginia.....
71 C30 Wrecker
Old 07-31-2013, 05:37 PM   #9
Daddy Brim
Daddy Brim's Avatar
You might find this helpful http://www.pbase.com/nufsed/drumbrake
Old 07-31-2013, 07:19 PM   #10
In The Ten Ring
Big Freaking Hammer! That's funny. Thanks.
Ah ha....so just put the jack stands under the shaft that goes into the wheels...got ya.
I ordered the copy of the original chassic manual but the pics are hard to see. I have a Haynes manual for those model years.
I've been watching youtube vids and I am getting a better idea. I talked to a friend who used to work in a garage....he warned me about not taking the parking brake off. LOL
Old 07-31-2013, 10:06 PM   #11
SS Tim
SS Tim's Avatar
Here is a link to download the factory service and overhaul manuals.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
If you are new to this to the point of wanting advice for jackstand placement it would be a really good idea to find a buddy to walk you through the project. I've had good luck teaching people on one side and watching/helping them do the opposite side on both axles. It makes for a good, safe learning experience. Taking pictures before you disassemble after a good shot of brake clean is very helpful in any case.
SS Tim is offline   Reply With Quote
Old 07-31-2013, 10:23 PM   #12
JointTech
JointTech's Avatar
yea drum brakes are a real PITA. Even when I had the old stuff and new stuff in front of me it takes a lot of figuring to put it back together.
mine only took a whack or two to break it free but I didnt have a big lip for the shoes to get stuck in.
also I dont have one of those holes in the drum to loosen the parking brake. I heard theres a knockout to get to it but fortuneatly I didnt have to use it.
fyi I got one side of my cab mounts done today. It wasnt nearly as bad as people make out. Just hard enough to make you feel like you did something. Unlike for example upper balljoints which make you want to sell the whole thing.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 07-31-2013, 10:28 PM   #13
Rufton
I bought the 12 ton jack stands from Northern Tool; very nice, tall and safe.
I don't recall them being that expensive.
If buy smaller stands make sure sufficient height for your truck.
Rufton is offline   Reply With Quote
Old 08-01-2013, 01:02 PM   #14
GRX
GRX's Avatar
^^ this!
I grew up in the era of drum brakes and have done far more than my share. The slide on drums most always rust around where it fits over the axle. Soak with penetrating oil for a while, hit the drum with a brass punch and BFH to break it loose. If that doesn't work apply some heat to the drum (not the center hub) with a torch. I have had them literally pop right off that way. Nothing like a HOT drum in your lap
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-01-2013, 06:28 PM   #15
In The Ten Ring
Thanks guys. I bought some basic drum tools today at Advance Auto. I'll give them a good look beginning next week. I still need to get a propane torch....thanks for the advice on how to use it!
I checked with a shop I like and worst case scenario (whole replacement) I'm looking at about $90.00 in labor. I can replace everything fairly cheaply from Advance Auto.
Old 08-01-2013, 07:43 PM   #16
Rufton
Maybe you can borrow some jack stands or buy used if you wan't to save a buck.
Old 08-01-2013, 07:57 PM   #17
Mike C
Mike C's Avatar
Everybody should own jackstands. Go to grocery store and look at car mags that have harbor freight coupons. Find one that has 6 ton stands for $25. Take picture of coupon or buy magazine. Order. Work on truck.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-01-2013, 08:06 PM   #18
Rufton
I frequent HF and their stands are probably fine, but an inside voice told me to not to buy the cheapest stands.
Old 08-01-2013, 08:20 PM   #19
PanelDeland
HF and NT both have decent jackstands.Look for real steel.If parts of them are stamped of light guage,make sure your insurance premiums are paid.Preferably,get good ones so we can have you around for a good while longer.
Old 08-01-2013, 08:41 PM   #20
swamp rat
swamp rat's Avatar
I got to agree with the post above on using a brass drift with the BFH, if nothing else i't even try an aluminum block or something, better to dent up a drift than the drum, a couple good hits, rotate 180, couple more hits ect.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-02-2013, 03:28 AM   #21
In The Ten Ring
I was right over at Advance Auto TWICE today and I forgot to look at jack stands! My dad has some HEAVY steel ones he made in the coal mines (he was a welder back when 1/2 inch steel was just given away) but he'd never find them in all his junk and then he'd be upset I was actually working this intensely on the truck. He doesn't approve of my cleaning out the old gasoline or fuel system.....I just don't tell him anymore what I do.
