Old 07-31-2013, 10:08 AM   #1
HardKoreKustoms
HardKoreKustoms's Avatar
67 swb stepside wheel fitment
so i know this is been covered and beem lookign but cant find the answer that i need, i see alot on tubbing but since i am running open bed (floorless) all i need to do i trim the bed side up a little, but i am about to order a set on the mob steel wheels and wanted to run a 18x10 up front and a 20/12 in the rear can i do that or should i stick wit a 18x8 and 20x10, will i have any fitment problems and what backspace should i use to have the rear wheels tuck, also with the 18x10 i should still be able to turn stop to stop, the truck is going to be a custom frame that will sit about half inch from rocker when layed out, and about a 4 inch when aired up, if that helps, with full custom cantilevers.
HardKoreKustoms is offline   Reply With Quote
Old 07-31-2013, 11:02 AM   #2
HardKoreKustoms
Re: 67 swb stepside wheel fitment
anyone.. maybe a link to get me where i need to be.?
Old 07-31-2013, 12:10 PM   #3
hdzammo
hdzammo's Avatar
too many variables. i dont think a 10" wide up front would work. the 12" would work on the rear depending on backspacing and of course cutting the bedsides.
hdzammo is offline   Reply With Quote
Old 07-31-2013, 02:31 PM   #4
HardKoreKustoms
i think im going with 18x8 and 20x9
thats what mob steel carries
Old 07-31-2013, 10:11 PM   #5
502ms
502ms's Avatar
Yeah, 18x10 laid out is asking a lot up front.
18x8 +4.25 BS should do it for you up front. 245/40/18
20x9 +5.25 BS will make it work out back with the right size tire. 265/35/20
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-01-2013, 04:08 PM   #6
HardKoreKustoms
502ms thanks for the input you think 245 is the widdest on the back your build and another build on here influenced me building a stepper, i wanted to try a 275 or up will it fit in the fender well in the rear, what sixe are you runnign and what is the clearence you have.
Old 08-01-2013, 06:09 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
My opinion.
Build the chassis first.
Buy wheels last.
That way you can measure for correct fitment.
Keith
Convert to disc brakes.
