Old 07-31-2013, 12:07 PM   #1
valero
valero's Avatar
can't get the frame detached from the rear springs???
how's it goin everyone!
so, I'm trying to pull the rear end off of my donor frame, but can't seem to get the bolts that good the springs to the frame loose...??. the frame has been powder coated, but I'm using an impact wrench and it's not even moving. should I come in from the inside of the frame and try to loosen the nut with some heat and a wrench with a breaker bar ?
I have to get this thing moved ASAP, so any quick advice would be helpful!
thanks!
valero is offline   Reply With Quote
Old 07-31-2013, 01:41 PM   #2
BK'66Step
BK'66Step's Avatar
Re: can't get the frame detached from the rear springs???
If you aren't trying to save the coils, cut them off. Had to do that on mine.
BK'66Step is offline   Reply With Quote
Old 07-31-2013, 02:03 PM   #3
valero
valero's Avatar
lol...yeah, I've got a new set, so that seems likethat's the best bet at this point.
shoulda just done that in the first place! hah. BTW how did you get the coils off after though, just elbow grease or?
thanks for the response, man.
cheers.
Old 07-31-2013, 08:56 PM   #4
BK'66Step
BK'66Step's Avatar
After cutting the coil out, I cut the bottom bolt off on top of the trailing arm (very carefully) and the top bolt from the bottom of the frame, if that makes sense. If I had had a torch, I might have heated them up first to see if they could move but since I wasn't saving them I didn't see the need.
Old 08-02-2013, 02:28 PM   #5
valero
valero's Avatar
I hear ya...I'll probably torch em first and see if they'll move.
btw, that cutting wheel went through those things like butter!
literally took less than ten minutes for both, lol. saved so much time!
