Old 07-02-2003, 11:06 PM   #1
Lil Greg
Question p/s pump
This is my first time posting on this part of the board but i thought yall could steer me in the right direction, ok i'm putting a 68 big block in my 75 truck and need a p/s pump and the brackets can i use ones from a 67-72 truck and if so are they for short or long water pump and where can i order them...........thanks
Lil Greg is offline   Reply With Quote
Old 07-02-2003, 11:55 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
up to 72 turcks would have had short water pumps. 1973 and up are long water pumps. You will want to find the long set up for your 75. They are much cheaper and easier to find. i think somebody here was asking 75 for the longs and 225 for the short set up a while back.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 07-03-2003, 12:42 AM   #3
beau396
I put a bbc in my '67 and went with the swp setup. It would have been a lot easier, and cheaper to go with lwp stuff instead. However you can get most of the stuff in reproduction parts from vendors such as year one, just look for '65-'67 chevelle bbc parts. Still by the time it is all said and done you will have at least double, but more likely triple the amount of money tied up in it. however if you still want to go swp I can point you in the right direction as far as finding parts just drop me a pm.
'67 C10 short box fleet side wood bed small rear window frame off restoration. 396BB,Th400, ps, pwr disc 5 lug, posi 3.07, 2000 Suburban 60/40 pwr seats, 2.5" front drop 4" rear, powder coated running gear.
beau396 is offline   Reply With Quote
Old 07-05-2003, 09:25 AM   #4
Daves72'GMC
where can I get a BB ps pump pulley? Mines a little warped. Thanks
Daves72'GMC is offline   Reply With Quote
