Old 07-31-2013, 07:50 PM   #1
tylervalo
Steering column swap question
I just got a column from an 89' 4 speed Suburban, will it have any difficulty swapping into my 84' automatic (converted to 4 speed) K10 cab? I'm specifically thinking about stuff like high beams and other wiring things.
tylervalo is offline   Reply With Quote
Old 07-31-2013, 10:15 PM   #2
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: Steering column swap question
Someone can correct me if I'm wrong...
But I believe the columns are the same for the 1984-1991 old body style trucks (excluding of course the 88-91 New body style C/K pickups)
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-31-2013, 10:17 PM   #3
tylervalo
I know pre 84 had the wiper on the dash and high beam on the floor. I was pretty sure before I bought it everything would work, I was hoping no cutting and splicing would have to occur.
Old 08-01-2013, 10:50 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
-Sam
I believe too,some need the lower shaft is all I've heard
dimmer, pull the wires from the actuall plug,move to newer style
wipers ,working on it, heard it's wired diff
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-01-2013, 06:22 PM   #5
SamsAutoParts73-87
yeah 78 and older is the only time you need to worry about the lower shaft.
79-83 is all the same, the 73-78s are hard to interchange unless you swap out the turn signal switch
Also some of the 78s used the 79 and up steering shaft b/c I have a 78 tilt column in my 79
-Sam
