07-31-2013, 08:50 PM | #1 |
what is the best radiator to buy!
So i found out i have at carbureted LS1 motor. it also has a cam in it, but still trying to find out what kind it is. I am interested in buying a aluminum radiator with electric fans because I live in Las Vegas and im afraid the heat may be to much. I have found some 2 tubed radiator with 1 in. tubes may be better than those with 3 or 4 rows that have smaller tubes. The truck should have about 400 to 500 horsepower by the time i get done. but i want to get the proper radiator right now. any help would do. thanks
07-31-2013, 10:14 PM | #2 |
Re: what is the best radiator to buy!
We are a Gold Vendor here, and we make hand-made aluminum crossflow radiators that are drop-in (no fabrication or cutting required) right here in the USA, with US-sourced materials. No epoxy, no plastics, and TIG welded. Our units are 2 core, utilizing 1" thick cores each, for a total thickness of 2" at the cores (same thickness as a traditional 4-core brass & copper). We started a thread in the vendor section, where you can read about our set-up along with pricing and member discounts:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670 |
07-31-2013, 10:59 PM | #3 |
I went with the entropyrad set up, I am very pleased with the quality
1970 Chevy swb, project UGHH! 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ |
07-31-2013, 11:00 PM | #4 |
Double post
1970 Chevy swb, project UGHH! 1987 Grand National http://s168.photobucket.com/albums/u.../1970%20Chevy/ Last edited by Expat_dude; 07-31-2013 at 11:02 PM. Reason: Double post |
07-31-2013, 11:04 PM | #5 |
thanks ill check both out
07-31-2013, 11:06 PM | #6 |
Thank you for the responses. ill check both of those out.
09-09-2013, 09:00 AM | #7 |
let me know if you have any questions about our radiators, I'd be glad to help
09-09-2013, 09:03 AM | #8 |
I went with a Griffin
Posted via Mobile Device |
09-09-2013, 09:51 PM | #9 | |
09-12-2013, 11:13 PM | #10 |
Thanks Fitz. its good to here from someone that has the same weather as i do. our heat is different than the heat on the east coast. ill check Be cool radiator 4 row.
09-14-2013, 09:16 AM | #11 |
also be cautious of the depth of the radiator. We build ours with dual 1" thick cores, for a total thickness of 2". Much more than that, and you start bottle-necking the air as it passes into the core, and can cause the air to be forced around the radiator instead of through it.
09-14-2013, 07:27 PM | #12 |
Classic Industries has an aluminum sure fit for 339.00. I got one and haven't installed yet. Really nice construction. Made by US Radiator.
http://www.classicindustries.com/tru...l80901and.html |
09-14-2013, 08:19 PM | #13 |
Roto Reuter thats the name...
I have an aluminum radiator made by Wizard Cooling. Might right here in Western New York. They did an awesome job and I got a personal tour of their facility. Down to earth people and excellent product.
http://wizardcooling.com/1967-1972-c...minum-radiator
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
09-15-2013, 06:51 PM | #14 |
Here's the US radiator. They cost less and I wish I could spent 5-600 dollars for the hefty ones.
