07-31-2013, 10:57 PM | #1 |
Active Member
NOS exhaust manifold
Many 4x4 applications, just this one, $75 shipped, pp or m.o.
08-01-2013, 01:09 PM | #2 |
"Trucks with Class"
Re: NOS exhaust manifold
Ill take it IF it is Gen GM. I don't see the normal small casting/part numbers. Is this a repop? Made in the USA? thanks, frank
08-01-2013, 01:44 PM | #3 |
One of the First
Frank, I have set of these one of my 4x4's. As you can tell, they are late model with the emission control threaded holes on the side. I put plugs in mine - no leaks.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
08-01-2013, 01:50 PM | #4 |
Active Member
Mel, When I bought it years ago it did have the GM black/white Gr & Part # adhesive sticker on it. You can see the band outline next to the casting #. Of course now I can't find the label. Here are pics of the other side with another set of # and a symbol, maybe that helps? If your not sure, I understand.
08-01-2013, 10:43 PM | #5 |
"Trucks with Class"
I going to have to pass. That is a good looking casting, but it is a replacement. thanks, frank
08-15-2013, 09:49 PM | #6 |
harry, you still have this? i will take it if you do thanks
08-16-2013, 07:55 AM | #7 |
Active Member
Jim, yes, pm sent, Thanks
