Old 08-01-2013, 12:32 AM   #1
nightmare
nightmare's Avatar
Misc Wires?
Hey everyone, I've got these wires that I'm not sure what they go to (yet). I'm trying to see if anyone has any thoughts as to what they might do.
This small silver box is on the Passenger side fender, and has a yellow wire (on the right) and a red wire (on the left) on it. The yellow wire is coming from under the driver's side dash.
The red wire runs along the top of the radiator support, then connects to the left side of this on the driver's side radiator support. The right side then connects back to a yellow wire, that runs under the cab some place.
Any ideas? I've checked conductivity and there is some conductivity between the left terminal and the middle terminal, but nothing that connects to the right.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 08-01-2013, 12:40 AM   #2
Mister-B
Re: Misc Wires?
Well, it's definitely not stock, but you probably knew that. Does your truck have evidence of anything aftermarket, like stereo equipment, etc?
Mister-B is offline   Reply With Quote
Old 08-01-2013, 12:41 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Misc Wires?
Might be part of a camper wiring setup. The "little silver box" is a circuit breaker. I'm not sure what the other part is unless it is an older style inverter.
LockDoc
Leon
Old 08-01-2013, 01:14 AM   #4
FirstOwner69
FirstOwner69's Avatar
Re: Misc Wires?
The second picture looks like an old school battery isolator to allow the truck alternator to charge the house battery in the camping unit when in-transit but prevent a drain on the truck battery if the camping unit is left connected when camping.
Have you tried checking to see if the right terminal is hot when the engine is running?
FirstOwner69 is offline   Reply With Quote
Old 08-02-2013, 03:11 PM   #5
nightmare
nightmare's Avatar
Re: Misc Wires?
No, no aftermarket stereo equipment, but the wires inside the cab just terminate (go to nothing)
LockDoc
That might be what it was for. See below
I have, but it wasn't hot. The wires inside the cab were not hooked up to anything. I did remove it, and it says it is a battery isolator. Are these things worth anything? I'm never gonna use it.
Now I just need to remove the rest of the wires that went to it.
Thanks for the replies guys. I appreciate it.
Mike
67-72 FAQ
Old 08-02-2013, 10:19 PM   #6
FirstOwner69
Re: Misc Wires?
Not worth saving the isolator. Can't imagine anyone wanting it. Much better, more compact electronic units made today.
It appears it may have been installed on a factory camper wiring harness. Is one listed on your SPID? If so, you may want to salvage the harness wires and return it to stock appearance. I have some pics of my factory installation if you go that route.
