08-01-2013, 07:27 AM | #1 |
What make 205
Need help is this a np 205 but is it chevy or dodge
Posted via Mobile Device |
08-01-2013, 07:31 AM | #2 |
Re: What make 205
need a pic of the back to ID the case for sure. But it looks like a TH400 bolt pattern in the pic.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
08-01-2013, 08:05 AM | #3 |
Re: What make 205
08-01-2013, 08:08 AM | #4 |
Re: What make 205
NP205 for sure
08-01-2013, 08:10 AM | #5 |
Re: What make 205
08-01-2013, 08:11 AM | #6 |
Re: What make 205
08-01-2013, 08:22 AM | #7 |
Re: What make 205
Gm
08-01-2013, 10:36 AM | #8 |
Re: What make 205
yep, looks like a late model GM 205, slip yoke style, 6 bolt round pattern, 32 spline, found behind turbo 400's from '88-'92? and NV4500's '93 up.
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
08-01-2013, 10:44 AM | #9 |
Re: What make 205
Ok thanks
08-01-2013, 10:50 AM | #10 |
Re: What make 205
I got the same unit in my 85 K3500.
08-01-2013, 10:52 AM | #11 |
Re: What make 205
Round-6 TH400 version of NP205. For sure.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF |
08-01-2013, 11:04 AM | #12 |
Re: What make 205
What crossmember did u use to put it in ?
08-01-2013, 11:18 AM | #13 |
Re: What make 205
Its original to the k3500. It has the W style cross member.
08-01-2013, 11:26 AM | #14 |
Re: What make 205
It's not a round, its a figure 8 with a turbo 400 adapter
63 k20 with cummins 4bt, owned sence 1982 |
08-01-2013, 04:07 PM | #15 |
I built it
Re: What make 205
i dont see an adapter..?
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
08-01-2013, 07:58 PM | #16 |
Re: What make 205
That is a late 80s TH400 version NP 205. Figure 8 has a taller adapter, that one is short. Could be swapped in,but has the electric plug for 4wd on shift rail....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
08-01-2013, 10:23 PM | #17 |
I built it
Re: What make 205
actually should say, dont see the figure 8 part of it..
08-02-2013, 07:17 AM | #18 |
Re: What make 205
You must be partially blind.
08-02-2013, 09:47 AM | #19 |
Re: What make 205
Round pattern 205
http://www3.telus.net/u2slow/v3500/gm_np205_round.jpg 205 with turbo 400 adapter same as original pic http://www.google.com/url?sa=i&sourc...75536952803624 If you have to be rude maybe you should not be giving advice!!
08-02-2013, 11:15 AM | #20 |
Re: What make 205
I could be wrong, but most 1984 and down turbo 400 205 had figure 8 with adapters.
We dont need to be rude to have a discussion. The second pic in the above post is not what I was looking for sorry about that, wont let me edit now. And I cant seem to find one of the figure 8 to turbo 400.
63 k20 with cummins 4bt, owned sence 1982 Last edited by dieseldude4bt; 08-02-2013 at 11:31 AM. |
08-02-2013, 12:06 PM | #21 |
Re: What make 205
DirtRocket8x could you post a pic of the front of the case where the adapter bolts to it?
The one you have is a little to close to see the back of the adapter.
08-02-2013, 01:13 PM | #22 |
I built it
Re: What make 205
i have the one for the figure 8 and th400. it looks a lot like the th350-205 adapter..
08-03-2013, 12:04 AM | #23 |
Re: What make 205
After much photo searching it appears that the adapter I thought looked like my old 84 turbo 400 205 is in fact one on a round pattern 205 . I was wrong and can accept that.
Round patter turbo 400 adapter: figure 8 turbo 400 adapter:
08-03-2013, 10:12 PM | #24 |
Re: What make 205
I've watched your build, enjoyed it.
08-03-2013, 11:17 PM | #25 |
Re: What make 205
So what are the plans for the 205?
