Old 08-01-2013, 03:30 PM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
305 to 350
I've come to a great point in my build, but I need some help from you guys!
I'm picking up a Chevy 350 block this weekend, and I currently have a Chevy 305 in my truck so my question is, is what parts are interchangeable on these motors? I know I'll have to get different heads, and pistons for sure. Is the oil pan, crank, flex plate, harmonic balancer, timing chain, if there's anything missing can you please inform me on what can, and can not be switched over.
Thanks fellas!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 08-01-2013, 05:31 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: 305 to 350
Rods and pistons are useless so is the crank since its balanced for a lighter 305 rotating assembly. Heads-depends on what you have
Pan and intake obviously fit. Flex plate works timing chain should be tossed and replaced they are cheap enough same with the cam.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-01-2013, 05:49 PM   #3
77ChevySharkBite
Re: 305 to 350
Thanks Insidous what about the balancer can that still be used or should I get a new one of those too?
Korwin
Old 08-01-2013, 09:08 PM   #4
INSIDIOUS '86
Re: 305 to 350
Better to have a matching balancer. But usually they are neutral balanced since both engines are normally internally balanced.
