Old 08-01-2013, 03:54 PM   #1
swamp rat
swamp rat's Avatar
No spin?
On my glove box door the sticker has this listed:
G86 No Spin rear axle.
My question, does this mean limited slip? There is definitely nothing external to lock the diff, Its an Eaton HO72
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 08-01-2013, 07:36 PM   #2
Mike C
Mike C's Avatar
Re: No spin?
It means what it says. Like a limited slip, the no-slip or no-spin, works automatically- there is no external lever or button that needs to be engaged. It is the fore-runner to the Detroit Locker. Jack it up on the pumpkin and put it in neutural, NOT RUNNING, then rotate the tire forwards or backwards and if the opposite side turns in the same direction it is a no-spin. If it rotates opposite, it is an open diff.
I have a '70 GMC parts truck that was factory 4.57 and no spin (Dana 60) but when I pulled the cover off I found 3.73 open. So you never know exactly what your getting with an old vehicle.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-01-2013, 08:23 PM   #3
swamp rat
swamp rat's Avatar
Re: No spin?
Ok thanks, Just didn't know if it designated limited slip, if i do remember correctly they both do spin forward. Per your other comment, i couldn't agree more
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-01-2013, 08:47 PM   #4
SS Tim
SS Tim's Avatar
Re: No spin?
Like has been said it is a locking differential unit that replaced the spider gears inside the differential case. What makes you think your truck has a HO72? HO52 axles were stock for CK20 trucks.
SS Tim is offline   Reply With Quote
Old 08-01-2013, 11:13 PM   #5
swamp rat
swamp rat's Avatar
Re: No spin?
Keep in mind this is a uncertain guess gathered from what i have been researching on different forums and i have yet to prove anything out.
The HO72 and HO52 are mainly different by weight designation, and brake size, yet i cant find anything for sure on the brake size. But HO52 i think is rated at 5200 and the HO72 at 7200lb
Some of other stuff other "experts" say like the HO52 only has 2 spider gears Vs 4 for the HO72 dosent seem to pan out ether.
If you or anybody have any info or leads (even better a casting or stamping numbers chart) it would be greatly appreciated.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-02-2013, 12:05 AM   #6
SS Tim
SS Tim's Avatar
Re: No spin?
Been doing a lot of research, unless you think the axle has been changed it is probably the factory K20 HO52 (5200lb) axle. The brakes would be 11 x 2 3/4". There was also a Dana 60 (5500lb) usage in the K20s but that is very different looking intergral carrier style axle.
A C30 rear axle, HO72 (7200lb) has a heavier housing and 13 x 2 1/2" brakes on SRW trucks. Often people cite the load bolt that controls ring gear deflection as an indicator but it isn't. Fact is the drop outs are interchangable with the difference being the housing itself, the bearings, hubs and seals are the same. At this point the easiest thing to do is check the axle code and see if it is a K20 or a C30 application. There is no code overlap I know of between the two. But the catch is the carriers are code stamped and not the housings. There is an axle code chart in the parts manual.
Old 08-02-2013, 01:47 AM   #7
WIDESIDE72
WIDESIDE72's Avatar
Re: No spin?
I am sure that that gear swap adding quite a bit to the driveability of the truck. Talk about a stump puller!
WIDESIDE72 is offline   Reply With Quote
Old 08-19-2013, 05:23 PM   #8
swamp rat
swamp rat's Avatar
Re: No spin?
Would it be safe to say I have the ho-72? There is an adjusting screw on the driver side of the diff plus my rear drums are pretty big, my rims are 16.5 and my drums look to be about 3" smaller plus they have the heat dissipation ribs around the outside. I need to get under it and find some numbers soon. I can't upload pictures now
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-19-2013, 07:01 PM   #9
SS Tim
SS Tim's Avatar
Re: No spin?
11 x 2 3/4" C20
13 x 2 1/2" C30
Like I said earlier the load bolt is not a positive tell. The only way to know anything is to decode the drop out. The axle housing would have to be a judgement call based on original installation and brakes.
Why are you wanting this to be a HO72 anyway? The 13" drums are about impossible to find.
Old 08-19-2013, 07:24 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: No spin?
Correct me if I'm wrong.... HO72 always has the load bolt, HO52 some have it and some do not. My K20 has an HO52 with the load bolt, and FWIW the drums are finned.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-19-2013, 08:03 PM   #11
SS Tim
SS Tim's Avatar
Re: No spin?
That seems to be the pattern at this point. If you have a load bolt rear, post up the axle code stamped into it.
Old 08-19-2013, 08:08 PM   #12
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: No spin?
My drums are finned also.. now for the stupid question what is a load bolt?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-19-2013, 08:49 PM   #13
swamp rat
swamp rat's Avatar
Re: No spin?
Originally Posted by SS Tim View Post
11 x 2 3/4" C20
13 x 2 1/2" C30
I'm just trying to verify what i have because i want to convert to Disk brakes in the near future, i don't want to order a bracket or kit to find out that a HO-52 and HO-70 may have a different flange pattern. Humm, guess i could have asked/mentioned that a while back huh?
Yea i know 14 bolts are plentiful, I've thought about it a lot, i just want to go this route for now, i figure if i ever decide to convert to 14 bolt i can use the disk setup when i cross over as well if i cant find a 14 bolt already converted.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-19-2013, 08:54 PM   #14
swamp rat
swamp rat's Avatar
Re: No spin?
Point me to where i need to look if ya would save me some muck scraping time, Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-19-2013, 08:57 PM   #15
swamp rat
swamp rat's Avatar
Re: No spin?
Heres a link, its on the side of the carrier:
http://www.google.com/imgres?q=Eaton...6geaOCTrG0M%3A
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-19-2013, 09:02 PM   #16
Ol Blue K20
Re: No spin?
Thanks I'll check it out
Dale
Old 08-19-2013, 09:24 PM   #17
SS Tim
SS Tim's Avatar
Re: No spin?
The load bolt is used to prevent the ring gear from deflecting under load at the pinion gear (as in push away). It has a shoe that just floats against the ring gear under unloaded conditions.
Old 08-19-2013, 09:38 PM   #18
swamp rat
swamp rat's Avatar
Re: No spin?
Thanks for the explanation and pic, any idea what a proper clearance would be on it? i ask because the grease monkey at Jiffy lube thought it was to check the gear lube level, guess he never dealt with antiques before not sure if he messed it up but figure i should check the setting.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-19-2013, 09:42 PM   #19
Ol Blue K20
Re: No spin?
Thanks Tim..my 72 has the load bolt and I know for a fact mine is original to the truck. I just called the original owner and asked him I'm second owner
Dale
Old 08-19-2013, 10:24 PM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: No spin?
It's a work truck, not a show truck, and it's a bit crusty underneath. A quick look found nothing. Where should the numbers be?
- Mike -
RIP El Jay
Old 08-19-2013, 10:53 PM   #21
SS Tim
SS Tim's Avatar
Re: No spin?
All depends if he just wrenched it down or not.
Old 08-19-2013, 11:14 PM   #22
Re: No spin?
The axle flanges on HO52s and HO72s are the same. The brakes can be interchanges,as the 14-bolts can as well. The No-Spin is a locker,not a limited slip and only came in the corporate rears (HO series). They are Detroit Lockers that GM gave their own name to. The Dana 60s came with the Power-Loc which is a limited slip from factory (if optioned)
Old 08-20-2013, 01:34 AM   #23
swamp rat
swamp rat's Avatar
Re: No spin?
Don't know where you get these pic's but i sure wish i had that service manual! Thanks!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-20-2013, 01:39 AM   #24
swamp rat
swamp rat's Avatar
Re: No spin?
Thank you for that information!
I have all the No-Spin pamphlets and i'm fairly sure this is the stock unit, our family got this truck when it was a year old.. I'll find out soon enough
I don't want to open it up until i have all the disk brake parts i need front and rear, as well as a new booster and am ready to do the swap, cant buy it all at the same time so trying to save some coin and then dive in with both feet.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 08-20-2013, 02:04 AM   #25
SS Tim
SS Tim's Avatar
Re: No spin?
You can download workable and searchable copies of both the factory service manual and the overhaul manual here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Really not sure you need rear disc brakes. The kits I have seen either don't use a park brake at all or rely on a poor mechanical design intended for a much lighter vehicle.
If money is tight get your 72 front disc brakes up to as new with some quality pads, rotors, calipers and hoses. They do most of the work even more so on a lightly loaded truck. Then just go through and clean up the rears. Adjusted and working correctly they do a great job.
