Old 08-01-2013, 06:06 PM   #1
padresag
230-250 I6 hei
when one puts a hei in the earlier engs what spark plug do you run?
ron
padresag is offline   Reply With Quote
Old 08-01-2013, 06:17 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: 230-250 I6 hei
ron
Ron,
I was wondering the same thing. I visited Tom Langdon's website. He sells HEI distributors for the inline 230 and 250 engines. He also sells the correct plugs for only $1 each. He sells 2 different sizes, so be sure you get the correct size. I noticed that my 250 takes a different plug than my 230, but I can't tell you which one. Here's the web link.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 08-01-2013, 06:40 PM   #3
Sharps40
Re: 230-250 I6 hei
Gimmie 5 minutes to check,...I got langdons HEI and plugs in my 6, I'll check.
Sharps40 is offline   Reply With Quote
Old 08-01-2013, 06:47 PM   #4
Sharps40
Re: 230-250 I6 hei
Champion RN16YC5
I'm gapped at 45 thou...Tom recommends up to 60 thou on these plugs with his HEI. Believe his plugs are same for 194 thru 250.
I'm running Toms HEI, 18 degrees initial advance per Toms advice and though I started at 10 degrees, 18 is much better.
Carb is weber 32/36 DGEV progressive.
Old 08-01-2013, 06:53 PM   #5
tincan1966
tincan1966's Avatar
Re: 230-250 I6 hei
I use nothing but NGK V-power racing plugs. You can go to their website and cross reference your plugs.
They are usually only about $2 a plug. had real good luck using the .045-.048 gap. When using the MSD 6AL digital seemed to like about .055" gap better.
I figure if they will last in the Fuel Altered on 25% nitro-methane they ought to last on pump gas.
tincan1966 is offline   Reply With Quote
Old 08-02-2013, 01:55 AM   #6
Vernski
Re: 230-250 I6 hei
Originally Posted by Sharps40 View Post
Champion RN16YC5
I am running Tom's plugs & HEI also, I was wondering about the Weber how's it working out for you? and what intake or adapter are you using?..Vernski
Vernski is offline   Reply With Quote
Old 08-02-2013, 06:16 AM   #7
Sharps40
Re: 230-250 I6 hei
Toms intake adapter on my log. I made a new gasket, the slotted one leaks. The carb runs super awesome, better than perfect, bestist I ever had! Very tuneable. Pics of how I installed it, modded the linkage and all the tuning is in the John Lee Jr Thread. I can't really ever see a reason to use a Rochester B or MonoJet ever again on a Chevy 6
Old 08-02-2013, 10:32 AM   #8
MikeN
MikeN's Avatar
Re: 230-250 I6 hei
You can use the original/stock plugs, just open the gap up to something between .045 and .060.
MikeN is offline   Reply With Quote
Old 08-02-2013, 10:52 AM   #9
padresag
Re: 230-250 I6 hei
I thought that hei utilized a resistor plug? That was the reason that I asked the question.
ron
Old 08-02-2013, 01:18 PM   #10
Vernski
Re: 230-250 I6 hei
ron
Is the resistor plug like for radio static or other functions? I was just assuming that it was or is there other reasons Ron?..Vernski
Old 08-02-2013, 01:38 PM   #11
padresag
Re: 230-250 I6 hei
pretty well all plugs are resistor now and I don't really know whether or not for radio suppression alone or not as ignitions systems have advanced.
at one time one just put in an inline suppressor to block ignition interference from the radio and the came resistor plugs which also blocked it.. what they all do now is beyond me.
I stayed away from spark plugs for 20 years with my diesel
they just delivered some NGK 2635 plugs to the door. now to figure out at waht to set the gap to
ron
Old 08-02-2013, 01:42 PM   #12
padresag
Re: 230-250 I6 hei
here is a link for anyone that want to change their in cap coil to an external oil filled coil
http://www.chevytalk.org/fusionbb/sh...hp?tid/300403/
ron
Old 08-02-2013, 01:49 PM   #13
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: 230-250 I6 hei
In an old Hot Rodding issue, they recommended 3 different heat rated plugs. The hotter plugs went on #1 & #6 then the next cooler rated plugs #2 &#5 then the coolest at the #3 & #4. The thought behind this was the further away the fuel traveled, the hotter the spark required to ignite the mixture without burning the pistons. The cooler #3 & #4 did not need as much. R45 R44 R43 if I remember incorrectly . lol
Old 08-02-2013, 08:01 PM   #14
TJ's Chevy
TJ's Chevy's Avatar
Re: 230-250 I6 hei
If you can get NGK spark plugs you will be very happy! On my 292 I am running ngk spark plugs and they work way better then autolight or champion. I would highly recommend the NGK's.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 08-02-2013, 08:05 PM   #15
Irishbleueyes
Re: 230-250 I6 hei
I run these in my 283, so far so good.
http://www.e3sparkplugs.com/
Irishbleueyes is offline   Reply With Quote
