Old 08-01-2013, 09:06 PM   #1
mikeshome
mikeshome's Avatar
No Reverse Lights
I have a new to me 1971 GMC 1500 long box,automatic trans,Reverse lights not coming on .Just wondering if there are any common problems.I have not looked at it yet,is the switch under the dash on column or on the trans?Thanks in advance to any responce.
mikeshome is offline   Reply With Quote
Old 08-01-2013, 09:11 PM   #2
SuperC10Tex
SuperC10Tex's Avatar
Re: No Reverse Lights
On the the column, check fuse, check for grounding issues...
Good Luck!!!
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 08-01-2013, 09:20 PM   #3
SS Tim
SS Tim's Avatar
The factory neutral safety switch is also the reverse lamp switch. I'd verify power (key on) to the connector and measure the resistance of the lamp circuit to that same connector. IIRC the dk green is the power and the light green is the lamps. The two purples are the starter circuit. If they both look good try a fused jumper and see if the lamps come on. It might be a swicth or an adjustment but don't just jump in and replace it. Do the daignostics. Workable copies of the factory service and overhaul manuals can be downloaded here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
SS Tim is offline   Reply With Quote
Old 08-01-2013, 09:21 PM   #4
mikeshome
mikeshome's Avatar
Thanks will do that its the only thing on the truck that doesnt work.
Old 08-01-2013, 09:24 PM   #5
mikeshome
mikeshome's Avatar
ok tim,will check that also i do know the truck only starts in park or neutral so that part of the switch is working correct.Maybe both bulbs are just gone.lol
Old 08-01-2013, 10:30 PM   #6
cdowns
cdowns's Avatar
i'd check the light bulbs and the sockets first
Old 08-01-2013, 11:17 PM   #7
Lattimer
Lattimer's Avatar
After doing a lot of checking on mine, I found I had to add a ground wire to the light fixtures to make them work. They are supposed to ground to the body, but mine apparently weren't.
First thing is the bulbs, then check the sockets with a test light. Key on, shifter in reverse. If no power, start checking the switch and the wiring. If you have power, try grounding the fixture.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 08-02-2013, 09:38 PM   #8
mikeshome
mikeshome's Avatar
Thanks guys.Took a look at it tonight,Who would guess it would be as easy as 2 bulbs.Wish all repairs where that easy and that cheap.
Old 08-02-2013, 10:09 PM   #9
Daner
Daner's Avatar
The lights weren't working on my 67. After troubleshooting from the rear forward discovered there was no fuse in the holder.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
