Old 08-02-2013, 02:12 AM   #1
jerry73
Alternator not charging thus battery
Ok so I've been driving my sisters old 1978 ex-diesel 1500 with a carburated 454 out if a 1991 Chevy,my problem is I have a brand new starter,alternator,battery,and cables+ the cable from the battery to the starter...and it won't start unless I charge the battery every night,it only drains the battery when I drive it,I can let it set over night with a full charge and it'll be fine when morning comes,all the new parts I have have been tested and are all fine... Any ideas? Also sometimes when I go to start it there is sparks that I can see that are either coming from the drivers side under the truck or under the dash inside
jerry73 is offline   Reply With Quote
Old 08-02-2013, 03:45 AM   #2
kjc292
kjc292's Avatar
Re: Alternator not charging thus battery
loose wire or a short. get a meter and start going down the electrical system... there was a problem with a truck at my work with the batteries and there was a loose wire that always had a charge going through it, drained the batteries every night.
79' c20 std cab 292 3speed granny - daily driver.
77' c30 std cab 454 th400 4.10 - fathers truck then mine.
95' ford bronco 302 4speed overdrive.
2002 mustang auto v6 - girlfriends daily driver.
Debt just means that you had more fun than you're suppose to have
kjc292 is offline   Reply With Quote
Old 08-02-2013, 03:48 AM   #3
kjc292
kjc292's Avatar
sorry read the post again, possibly the ground wire not completely grounded, a cable somewhere with exposed wires or also a starter solenoid.
Old 08-02-2013, 08:22 PM   #4
jerry73
I don't have a meter yet but it's on the list of tools I need... I should also note that the truck will start excellent if I turn the distributor clockwise about 1/5 of a turn,but then she runs like $h!t
