Old 08-02-2013, 11:38 AM   #1
1969shortbed6.0
Front tire width help
I have a 69 c10 lowered with 2.5 drop spindles in the front. Will i have clearance issues with a 275/60-17 tire and wheel with a 4'' backspacing and zero offset mounted on the front? I want to run the widest tire I can on the rear but also be able to rotate all 4 tires. If this tire is too wide for the front what is the widest tire i should clear on the front? All help is greatly appreciated. Thanks, Joe
1969shortbed6.0 is offline   Reply With Quote
Old 10-05-2013, 11:38 PM   #2
cool68
Re: Front tire width help
how often will you need to rotate tires? buy some that fit right in front and other size for rear.
cool68 is offline   Reply With Quote
Old 10-06-2013, 01:33 PM   #3
Fitz
255/60 R17 were the biggest I could fit with an 8 inch wheel. 275's are a bit too wide.
Fitz is offline   Reply With Quote
Old 10-06-2013, 06:09 PM   #4
ugotd8
^ +1
These are not 17s, but 15x8, 4.25 backspacing, 255/60/15 -- almost too wide...
My 3D Gallery
ugotd8 is offline   Reply With Quote
