Old 08-02-2013, 02:31 PM   #1
Lees68GMC
Lees68GMC's Avatar
Newby- My first Questions
I'm disc braking (1.25 rotors) and using McGaughey 2 1/2" drop spindles, 5 lug on my 68 GMC SWB. Tires on it at stock height were 275-60-15 BFGs on 8" wide alloy wheels.
Does anybody Know or have personal experience here, Can I run 15 X 10 Corvette style 5 lug Rally Wheels (5" back space) with the Same 275-60-15 BFGS on All for corners without serious clearance issues?
Rephrased;
With the same size tires that clear NOW on all four with 8" wide rims at Stock ride height, can I switch to running NEW 10" wide steel rims and the same exact tires at a 2-1/2 front spindle drop and a 2" rear shackle drop?
Thanks Guys
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 08-02-2013, 10:04 PM   #2
70cst
70cst's Avatar
Re: Newby- My first Questions
Rephrased;
Thanks Guys
Hey Lees68GMC ...
1st of all--- to the forums and from Ohio.
I think the bolt hole for our trucks are 5x5 so the Corvettes wheels will not work. I will let other chime in.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-02-2013, 10:23 PM   #3
mmiddle
mmiddle's Avatar
Welcome from Texas.
Where are you in Prescott? My daughter goes to Embry Riddle. We are there two or three times a year.
It sure is beautiful out there. Maybe we can meet up next time I'm out there.
2x on the Vette wheels.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 08-03-2013, 09:31 AM   #4
Tinkermc
Corvette's are 4.75" bolt pattern and your truck would be 5". I can't say about clearance but fit is out. They do sell 5x5 corvette style wheels.
Tinkermc is offline   Reply With Quote
Old 08-03-2013, 09:41 AM   #5
big mike71
big mike71's Avatar
I think he's talking about the corvette style rallies that they make for trucks. I think 10" will work on the back, but not the front.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 08-03-2013, 10:26 AM   #6
502ms
502ms's Avatar
10" front would require major backspacing (6.5" or so) or some kind of narrowing on the frame. I wouldn't attempt it
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-03-2013, 06:17 PM   #7
Lees68GMC
Lees68GMC's Avatar
Thanks for the Welcome here,
A little rehash, I have McGauheys 2-1/2 drop spindles, but for a 1974 Chevy C10 Lug pattern is 5 on 4.75, (later I'm changing my rear axles to the same 5 on 4.75 I have a complete 74, 10 bolt rear end.)
Right Now, I've installed new upper and lower ball joints (74 they fit the 68 control arms and New drop spindles fine. I have new 74 tie-rods and adjuster collars. The only hurdle now seems to be the 68 drag links' inner tie rod holes are for the smaller tie rods (reemer maybe?)
Also my wheels are after market "Corvette Style" Vintiques from Summit they are dual lug pattern 15 X 10 with 5" back spacing, Rear tire & wheel combo is no problem. Again down to splitting hairs, my truck already had the 275=60-15 all around with no clearance problems BUT non 15 X 8" wheels. NOW me Not being a wheel genius here but my thinking was that if the tire cleared before and if the back spacing is the same, I'm only gaining 1" outboard and 1"inboard of the backspace center line Right?
Thanks guys for your help, I may be out in the Ozone with the direction I've started but I think I can make everything work. PLAN "B" is get 15 X 8 and maybe smaller tires too for the front only.
98 Chevy Blazer ZR2
