Old 08-02-2013, 02:34 PM   #1
Jacobsen62
How do I get the cover back on on a sm-465 tranny
I bought a 4 speed tranny to swap my automatic in my 88 v30 Chevy diesel and it got stuck in gear Riding in the bed of my truck on the way home. I pulled the cover off to get it to work again and now I'm having trouble lining up the forks to get the cover on. Is it suppose to be in a gear or in neutral? Any help or advice would be appreciated. Thanks
Jacobsen62 is offline   Reply With Quote
Old 08-02-2013, 11:20 PM   #2
mrolds88
Re: How do I get the cover back on on a sm-465 tranny
IIRC forward gears need to be in neutral position and reverse needs to be about 1/2 way engaged. Wiggle a little and should go in.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-02-2013, 11:45 PM   #3
meatwagon83
meatwagon83's Avatar
yup this^^^^ me and a buddy did this exact thing a couple weeks ago
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 08-11-2013, 02:45 PM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Did that work? I've got to swap shifters between two trannys. So you just make sure both are in neutral and work the shifter halfway to reverse as you reinstall?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-11-2013, 03:58 PM   #5
79Betty
79Betty's Avatar
Do u need jus the lever or the entire forks and all? If it's just levers then push down on the ball like thing and turn counter clockwise and it'll pop out. If whole then yea it'll work
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 08-12-2013, 07:45 PM   #6
68Timber
68Timber's Avatar
I really just need to swap shift levers. I have two, but the one I want to use has a long extension welded on.
John
74 Honda Z50 build
Old 08-12-2013, 07:52 PM   #7
79Betty
79Betty's Avatar
Pus down on the ball. Turn c-clockwise pull out. Make sure transmission is in neutral. New one put in and push down turn clockwise. Should be good to go!
Old 08-12-2013, 07:54 PM   #8
68Timber
68Timber's Avatar
I've got them in a warehouse at work. I'll try that tomorrow. Thanks man!
John
74 Honda Z50 build
Old 08-12-2013, 08:00 PM   #9
79Betty
79Betty's Avatar
Some people push down with c-locks, crescent wrenches all sorts of stuff. I use my thumbs but anythin will work
