Old 07-03-2003, 01:59 AM   #1
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
TH200-4R / TH350 swap
Has anyone replaced a Th350 with a TH200-4R tranny?
How hard was it and how hard would it be for me (19 yrs. old w/ no tranny experiance)? (But we have a family friend in the tranny bussness)
Did you just instal a floor shifter instead of the one on the colum and get a new steering colum (maybe a tilt one )?
Aren't the main things moving the rear bracket about 6" , adjusting the trottle valve, and the shifting part?
And did you buy a new one (and from where) or a used one from the treasure (junk) yard?
Thanks a bunch,
Michael
[FONT="Impact"][COLOR="Navy"]Michael
Lowered 1972 C-20 Longbed with 350 and TH350
1995 Tahoe LS - Custom intake, k&n, TBI spacer, sweet tail lights, clear front lights...
2009 Nissan Versa
I am 26, married, and we had our first baby in July of 2009
Iceman7642 is offline   Reply With Quote
Old 07-03-2003, 08:16 AM   #2
smokekiki
Mike
smokekiki's Avatar
You can hook it to the stock colum.Lokar has an adjustable linkage that works real nice,allthough the stock will work.I have a bench in my suburban with the stock tilt.It has a 700r4.Not sure how far to move the crossmember on a 200.The tv cable must be installed and adjusted correctly.Have someone check the line pressure for the best adjustment of the tv.Depending on the lenth of the trans you need to short the driveshaft.Speedo cable may need to be longer.Putting the trans in is not a real hard job.It is the same as any trans change.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 07-03-2003, 09:26 AM   #3
cdowns
cdowns's Avatar
i have a 2004R tranny that i got from www.fbperformance.com it's a bolt in deal no need to shorten the driveshaft you just move the tranny crossmember back to the holes for the th400 mount position, yes you can still use the original speedo cable, you can use the original shift linkage altho i went to a lokar floor shift and a tilt steering column it's a very easy bolt in deal the only thing a little tricky is the tv cable adjustment. i definately suggest that if you"re going to go thru the hassel of changing the tranny over you go for a freash performance build up , i've got 35K miles on mine not a problem
Old 07-06-2003, 09:55 PM   #4
Iceman7642
P!$$ on Ford
Iceman7642's Avatar
Thanks for the feedback
Michael
2009 Nissan Versa
Old 07-06-2003, 11:15 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Don't forget some sot of lock up kit for the converter. If you run it unlocked all the time it will slip excesivly in OD.
