6>8 Plugless........
![]() Join Date: Sep 2007
Parting out 72 Chevy C10 Highlander
I am parting out a 72 Chevy C10. It has the typical rust as these old trucks do. It needs cab corners, rockers, inner and outer, some floors will need replaced. It is a highlander truck but the seat cover is pretty bad. I have none of the original hub caps for it. Gauge cluster is gone. Truck has power brakes and steering. No power steering pump, or a/c brackets or compressor. If you see something not listed, please ask. If you need more pictures, please ask and I can get them for you. I will ship but please post a zip for you and I will get a quote for you. I will be traveling to Kansas City the weekend of September 6th and can bring parts with me as well. Thanks Ryan.
Chrome wing window vents $65pr Glove Box Door Spid is readable $30 AM radio with knobs, I don't know if it works or not $25 All A/C and heater components that remain on the truck $100 Front disc brakes, control arms, spindles, and rotors. Pending Vacuum booster with master cylinder, brackets, and porportioning valve. Sold Brake pedal assembly $30 Shift on the column steering column $30 Nice black 73-80 steering wheel $50 Rear trailing arms LH has no rust through and the RH has a spot starting Pending Rear end Pending Hood No longer for sale. Grill. No longer for sale. 4 core upper and lower radiator brackets $40 Steering Box $30 Good used windshield $25 Good used rear window $25 Front and rear window trim $40 Set of 4 rally wheels 2 15x7 and 2 15x8 $100
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 08-08-2013 at 09:35 PM. |
![]() Join Date: Dec 2011
Re: Parting out 72 Chevy C10 Highlander
Truck have dual note, high/low horns working? Shipping to 07748. Thanks.
You take 20 shipped for the stereo ?
1969 C20 CUSTOM "RUMBLEr" |
Does it have the parchment seat belts?
Price shipped to 37334. Thank You, CC |
I will have to check to see if the horns are there and get back to you. Thanks.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
$25 shipped via snail mail.
I think it does, but I'll have to check condition and see if they are all there. I'll look tomorrow and post back.
Are both of the kick panels solid right down to the base?
$40.00 for the hood? I wish I were local...... |
Here are the 15x8's.
![]() An under hood pic. ![]()
It looks lke it, but I'll have to check to be sure.
![]() Join Date: Nov 2002
How much would shipping be on the booster, master and prop valve to the 88240?
#13 |
It does have dual horns. I will check them to see if they work before getting a quote for you.
#14 |
#15 |
![]() Join Date: May 2002
I'm looking for the lower trim clips for the pieces behind the doors on the cab. How much for those, shipped to 77084, and can you take pictures of the clips still on the trim? Thanks.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#16 |
Through USPS $22.
#17 |
Let me remove them from the truck and see if they are still any good. I'll do it in the morning and post back.
#18 |
It has all the seat belts and they are parchment. I will try to get them out and get pics for you.
#19 |
I'll take the chrome vent windows and front and rear window trim pending shipping and pictures of condition of both.
#20 |
#21 |
#22 |
I could use the two braces off of the power brake booster if they don't go with the booster when you sell it. Let me know.
#23 |
![]() Join Date: Jul 2013
How much for grill shipped to area code 95665
Highly interested |
#24 |
![]() Join Date: Jan 2013
How much for the washer jug, bracket, & hardware? Is there an antenna from
this truck? I might be interested in the radio for $25 shipped if it works. Zip is 22630 Jamie 71 ![]() |
#25 |
Let me check, but I think I have an extra pair.
