Rebel wiring and a brake switch
This is the only bit of wiring I have left is to hook up the brake switch to this Rebel wiring harness. It seems like it should be pretty easy, orange wire on 1 side, white on the other and it should work right? Nope. I don't have any brake lights. Anyone have suggestions?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Re: Rebel wiring and a brake switch
Make sure there is power to one of the wires. If not, trace back up the line to the fuse panel with a test light or meter until you get power. Make sure a good fuse is in the correct location. Sounds silly, but I'm doing wiring right now and yesterday I spent 1 to 2 hours trying to find out why my AC harness wasn't working only to find out that I read AC/heat on the fuse panel and put the fuse below the writing when it should have been above. DUH! Changed the fuse and everything worked perfectly. If you do have power to the switch, press the pedal and make sure power goes through the switch. If not replace the switch. If it does, bypass the switch by connecting the two terminals together and work towards the brake lights with a test light or meter until you find out where the voltage stops. Then fix.
On some columns, like my 82 eldo one, the brake wiring comes from the column to the switch then to the brake lights.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
See if you have a kink in the wire somewhere. The electrons may getting jammed up, Just sayin.
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
On my rebel harness the key has to be on to get the brake lights to work.
Elev8r Man
Also, make sure you have a good and clean metal ground.
1955.2 C4 Carry-all / Suburban ![]() 1958 Fleetside SWB ---> 58 Fleetside Build thread 1939 2 door sedan My F.B. project page. |
do your blinkers work?
brake lights are the same as your turn indicator lights everything is controlled by the blinker switch check for 12v+ at the switch and then follow the instructions on wiring your tail lights all wires feed into the blinker switch and then out to all 4 corners of your truck 3 hot wires in: brake switch, flasher and hazard flasher; all feed 12v+ into the switch ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Everything works except the brake lights. I have tail lights, signals and hazards. I'm thinking its the brake switch itself.
Then try a jumper wire, I had to do that with neutral safety switch to prove it was toast. Good luck dubie.
I found the problem. I didn't have 12v power going to the turn switch. My hazard lights wouldn't turn on without the key being on and so, the same thing should go for the brake switch, seeing how it powers the brake switch.
Hmmm guess my idea didn't work after all. When I feed 12v power into the switch via the rebel hazard wire, the lights flash with the switch being turned off.
For the brakes, I have 1 white wire in the signal switch group that says brake lights. Then I have an orange wire and a white wire which are both labelled brake switch. Should the white brake light wire be tied into the signal stat 900 switch with the orange wire going to the hot side of the switch and the other white wire coming out of the switch? I may have required this entire truck, but it's all still Greek to me, I appreciate all the help I can get peeps. This is the last major thing this truck needs to have figured out before it goes in for inspection and exhaust tomorrow Posted via Mobile Device
Have you contacted Rebel Wire? They are great people to work with and will help you through any problems/questions you have. Give them a call.
