Old 08-02-2013, 11:28 PM   #1
Steve Cole
Anyone running this shutoff valve?
I don't know what it is called, but is there some type of shutoff valve that goes in line between the water pump and the heater core for non AC trucks? I am looking to be able to shut off the hot water that would normally circulate through the heater core in the summer. I don't need any additional radiant heat in the cab when it's 100 degrees outside.
What's it called and where can I get one?
Steve Cole is offline   Reply With Quote
Old 08-03-2013, 12:13 AM   #2
muckyp
muckyp's Avatar
Re: Anyone running this shutoff valve?
I've always referred to that as a heater core bypass valve. Old Air offers several.
http://www.oldairproducts.com/catalo..._33000000.html
http://www.oldairproducts.com/catalo...ve-p-3667.html
70 SWB 454/TH400
muckyp is offline   Reply With Quote
Old 08-03-2013, 08:13 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Anyone running this shutoff valve?
U can buy them at local auto stores. Manual shut off's. Just close it off during the summer. This is mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-03-2013, 08:44 AM   #4
Steve Cole
Thanks guys!
Old 08-03-2013, 01:50 PM   #5
mike88a
mike88a's Avatar
Okay stupid question. Which line do you put it on? Or do you need two of them?
mike88a is offline   Reply With Quote
Old 08-03-2013, 04:10 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: Anyone running this shutoff valve?
Only one per vehicle and it will stop circulation to the heater core. Most are 3/4" nipples so it's the 3/4" line but either or will do if it fits the hose.
Old 08-03-2013, 04:13 PM   #7
mike88a
mike88a's Avatar
THANKS!!!
It's hot here in Texas and a brother aint got no A/C just 2/55
Old 08-03-2013, 05:32 PM   #8
Tinkermc
the valves were at one time supplied with the ever popular flush kit.
Tinkermc is offline   Reply With Quote
