08-03-2013, 10:54 AM | #1 |
89 c30 upper control arm steel bushing worn?
hello guys i have had a death wobble in my truck its only at 35-40. i have checked out every suspension steering component and all seem to have very minimal play except for the driver upper control arm front bushing. i know there a steel type bushing. do the wear? or is the movement from the control arm hole somehow being elongated?
08-03-2013, 12:04 PM | #2 |
Re: 89 c30 upper control arm steel bushing worn?
Just replace the 24 year old worn out rubber bushings with new rubber bushings and you will be fine for another 24 years. And as far as i know no one makes a steal "bushing" for the upper control arm. And if they did, you wouldn't want it.
08-03-2013, 12:09 PM | #3 | |
Gentleman Jim Driver
Top pic is a half ton upper control arm with the rubber bushings, lower is a 3/4 and 1 ton upper control arm with the metal bushings. Pics are from ACDelco and are accurate. Buy new shafts and bushings from ACDelco or Moog. It will fix the slop. Keep them greased.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed Last edited by ElGracho; 08-03-2013 at 12:22 PM. Reason: added pics |
08-04-2013, 06:49 AM | #4 |
I just noticed this post was about an 89. If it isn't the 73-87 body style (like an 89 crew cab...), I'm wrong.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
08-04-2013, 07:54 AM | #5 |
Watch out for your cornhole !
Heavy trucks used steel bushings rather than rubber ones. It's the same type of bushing that all trucks used prior to 73. They are much heavier duty and GM continued to use them for many years in severe service applications.
Listen to elgracho. Rockauto and other places sell the bushings and shafts. Posted via Mobile Device |
08-05-2013, 12:35 AM | #6 |
It's an r3500 so yes it's a crew cab... I ordered new shafts upper and lowers with bushings I just didn't think they would wear out when I looked at them
Posted via Mobile Device Posted via Mobile Device |
