08-03-2013, 09:36 PM | #1 |
carburetor leaking
Guys, I know very liitle about carburetors. I believe mine is a Rochester and its leaking gas at the base. Doesnt seem to do it all the time, but got to get it fixed. I could use some advice. Thanks
Figure out what you want--then figure out what you are willing to give up to get it. |
08-03-2013, 10:08 PM | #2 |
Re: carburetor leaking
Had the same problem recently:
Of course the obvious - ensure all fittings are tight and carb to manifold bolts are tight. if its leaking from the carb/manifold surface might need a new gasket. Another thing to double check would be the float level - if they're not adjusted properly the bowls will fill too much and cause fuel to leak. Try to find the model number and check out the manual - many times they will have a troubleshooting step by step section. |
08-03-2013, 10:10 PM | #3 |
manifold/carb gasket link
http://www.rockauto.com/catalog/x,ca...parttype,10024 caution to not over tighten the carb bolts
MusicMan70 1961 GMC Suburban |
