Old 08-04-2013, 12:08 AM   #1
BlackedOut67shorty
BlackedOut67shorty's Avatar
Question 1/2 ton master vs. 3/4 ton
Okay I know the differences between the two how the 3/4 ton master cylinder is backwards to the half ton. I've tried searching for the thread about someone asking the advantages the 3/4 ton has over the half ton.(if it even does) But I only get threads about people asking about the boosters, so is the 3/4 ton master any better than the half ton or is it just the same, just reroutes fluid differently. I wanna know since my master crapped out on me and I'm looking for something better, I have 71 style brakes on my 67, thanks for the replys.
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 08-04-2013, 12:27 PM   #2
BlackedOut67shorty
Re: 1/2 ton master vs. 3/4 ton
Common they can't be the same just backward reservoirs
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-04-2013, 12:50 PM   #3
treveiger
treveiger's Avatar
With my c20 disk swap I needed new lines from mc to prop valve that was about I think. I'm not positive but I think the c20 mc has more pressure to it. I'm sure someone will chime in.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 08-04-2013, 05:29 PM   #4
BlackedOut67shorty
Thank you treveiger, I kinda thought so just wanted to double check.
1995 s10 blazer 4.3
2000 mercury sable
Thats a how I roll
Old 08-05-2013, 01:11 AM   #5
treveiger
treveiger's Avatar
No problem. Glad I could help!
Old 08-05-2013, 01:48 AM   #6
68shortfleet
According to my Raybestos parts book, the 1/2 ton master cylinder bore is 1.125" and the 3/4 ton bore size is 1.250". This means more fluid going to the calipers and wheel cylinders. However that also means YOU need to push on the pedal harder to make that extra fluid work unless you also add the power booster from the 3/4 ton truck. My understanding is that they got a larger booster that provides more power assist to balance out the extra effort needed at the pedal. I don't have a book of the boosters for comparing numbers on them though.
68shortfleet is offline   Reply With Quote
