Old 08-04-2013, 01:38 AM   #1
longbed65droppedc20
steering column
I have a 65 c20 it has a 3 in the tree. I currently bought an automatic tilt column is there any way of measuring the column to make sure it will fit.
longbed65droppedc20 is offline   Reply With Quote
Old 08-04-2013, 01:48 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: steering column
I bought a 32" tilt column when I did mine (I did use a multi-piece DD shaft however, so I had room to play with in mounting it.)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-04-2013, 01:51 AM   #3
longbed65droppedc20
Re: steering column
32 inches from where to where
Old 08-04-2013, 02:08 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: steering column
STEERING COLUMN FAQ - FLAMING RIVER
Old 08-04-2013, 02:20 AM   #5
franken
Re: steering column
Measure the old and new column. Look at the numbers?
Math is hard. Stupid is harder...
franken is offline   Reply With Quote
Old 08-04-2013, 03:02 AM   #6
longbed65droppedc20
Re: steering column
what numbers? where can I find this info
Old 08-04-2013, 06:25 AM   #7
tincan1966
tincan1966's Avatar
Re: steering column
Several factors at play here, and not much info given to be able to answer you.
"will it fit" is an open question- anything can be made to work-given enough fabrication skills and time.
A) what type of column did you get/ an aftermarket custom for these trucks? a salvage yard piece from a later model vehicle?
B) you measure a column from the end of the shaft(firewall end) to the top of the collar, just below the steering wheel.
C) Generally, a 32" column is recommended for these trucks, but a lot of us "beefier" guys like to use a 30" for a little extra room
D) there will be fab work involved, even with a "bolt in" as you will have to modify or replace the intermediate shaft between the column and the steering box.(the original is one piece)
It's hard to help people on here when not much info is given.
tincan1966 is offline   Reply With Quote
Old 08-04-2013, 11:25 AM   #8
longbed65droppedc20
Re: steering column
I bought the column from someone that did not know what car/ truck it came from. it's from a later model. not a new made to fit
Old 08-04-2013, 12:45 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: steering column
Did you look at any of what was posted?
How long is the column you have?
Old 08-04-2013, 02:25 PM   #10
tincan1966
tincan1966's Avatar
Re: steering column
How long is it?
Post a picture so maybe someone can help identify it, or else you'll have a hard time getting parts for it, if they are ever needed.
