fuel draining
what can be done to help stop the fuel from draining out of fuel lines when truck sits,some times it will run battery down be for it starts,besides drive it more,thanks guys
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
#2 | |
The Older Generation
Re: fuel draining
LockDoc
Re: fuel draining
Wow that's interesting! I wonder if my Rochester Monojet (in carb filter) would do the same thing if I left out the filter?
So many great things to learn on this site! And I hope you get this issue taken care of man. |
Old member
The mechanical fuel pump is suppose to have a diaphragm to keep it from going back past the pump also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Active Member
![]() Join Date: Jul 2007
Re: fuel draining
Also would help to know what carb you have.
If it's a quadrajet it may have well plugs leaking. Common problem on them and you need to dismantle to epoxy them. You can google quadrajet well plugs leaking for tons of info. Here's some info on a different fix. http://quadrajetparts.com/rochester-...h-t-12_21.html
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Re: fuel draining
i have a brand new edelbrock,and new fuel pump,on that truck,i have a 66 gto with a edelbrock,and a camaro with q-jet,and don't have that trouble,some times they will crank a little before they start,but nothing like this truck,thanks guys
Look at post from Andy4639--get a new fuel pump?...would be my vote!
Sam |
