350 5.7 vortec engine
For Sale $1700.00 Local pick up only.
Casting #10243880...350...95-00...2 or 4... Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal Stamp pad is V0412XJA New Heads are Pro-Topline cast iron Vortec style 58cc assemblies pn 223 5894 059 Has new Comp cam computer controlled 08-304-8 266HR-14 210 220 @.050 114 LSA .500 .510 New rockers, roller lifters, comp camp push rods New CP pistons flat top with valve relief’s .030 over and rings Block is a 4 bolt main bored .030 over, crankshaft is standard polished New connecting rods New timing cover New timing chain and gear New Chrome valve covers All new bearings New flex plate New Pro comp carbureted intake New Brass freeze plugs New oil pan New thermostat housing New harmonic balancer New fuel pump and shaft New short water pump New/modified Temp bulb for a 1972 350 This engine was built in November of 2012 it is estimated to make 360 hp 9.5:1 compression ratio and has not been run. I bought this engine assembled and set it up for my 1972 c10 or my 1969 K5 Blazer. The bottom line here is I need the money to help fund another project. Thanks for looking. Last edited by asolde; 08-04-2013 at 12:17 PM. |
