Old 08-04-2013, 04:32 PM   #1
SCOTI
SCOTI's Avatar
Be Thorough When Searching For Parts!
I'm going to replace the steering shaft assembly on my CC since I'm upgrading & cleaning things up in the engine compartment (ok... the whole truck actually).
So I check my local Oreillys & didn't see anything (could have been an internet deal as their site was experiencing issues). So I figured I would check w/the frequently marketed LMC to get an idea of possible costs. I about freaked when I saw the price for their 73-91 steering shaft kit....
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=136
Knowing that LMC doesn't make these, I decided to check a common manufacturing source for steering gear (Borgeson). Low & behold, I find the same thing. Even the description used is the same so my guess is this is where LMC is sourcing their part from. Lets see if you notice the BIG difference....
http://www.borgeson.com/xcart/catalo...ck-p-1448.html
So knowing this, I check the common aftermarket parts supplier Summit & find they offer the Borgeson parts line. A quick search using the p/n of this item & it's less vs from the mfr ....Plus, it's eligible for their 'Free Shipping' offer....
http://www.summitracing.com/parts/brg-000934
So be sure & do your homework when looking for parts. Sometimes digging a little deeper has it's rewards.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-04-2013, 04:43 PM   #2
JCampbell
Re: Be Thorough When Searching For Parts!
X's 2
I always check, double-check, and check again when looking for parts. Sometimes spending fifteen minutes can save you a decent chunk of dough.
Search part numbers on Amazon and eBay, too. I've gotten parts listed for almost $50 at Napa for $10 via Amazon.
JCampbell is offline   Reply With Quote
Old 08-04-2013, 05:16 PM   #3
geezer#99
geezer#99's Avatar
And if you look on CPP they have them for 110 bucks.
http://www.classicperform.com/Store/...ck/6768RJC.htm
Old 08-04-2013, 07:04 PM   #4
SCOTI
SCOTI's Avatar
What's the actual p/n? When I checked there, I couldn't find a match.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-04-2013, 07:34 PM   #5
geezer#99
geezer#99's Avatar
From my catalogue.
6768RJC.
Which appears to have been changed out.
Try this.
Look for collapsible steering shaft.
http://www.classicperform.com/Store2...roducts.htm#20
Old 08-04-2013, 10:25 PM   #6
BONUSCAB
Or you can hit up craigslist/forums/local junk yards and get a steering shaft out of a Jeep Cherokee; they are double u-joint models and about bolt right in. (Small bit of work to make them work.) The Jeep shaft eliminates the rag joint completely. I scored mine at the local junk yard for $17.
BONUSCAB is offline   Reply With Quote
